parkysmanta Posted January 13, 2013 Share Posted January 13, 2013 right guys, hope you all can help.... looking into running bike carbs on my xe as a cheaper route than carbs. but not really sure on setup etc or which is the best dizzy to use for my engine its a coscast lump, i wana ditch ecu etc and just use distributor for tidyier look and change heater, is the original xe dizzy alright to use or H and H solutions a good shout.. any help on setup would be great thanks all Quote Link to comment Share on other sites More sharing options...
rutts Posted January 13, 2013 Share Posted January 13, 2013 easiest for dizzy is an astra gte mk1 dizzy and have h+h solutions modify the advance curve to match xe. fits in same hole as xe and use a standard manta 1.8/gte ignition coil and wiring. H+H may have a dizzy for you in stock or try astramk1.oc. if you go onto events topic page contact chris hardman he is local astra club rep in northwest of uk. Quote Link to comment Share on other sites More sharing options...
parkysmanta Posted January 13, 2013 Author Share Posted January 13, 2013 awesome, thats just the info i was after cheers Quote Link to comment Share on other sites More sharing options...
