Adjustable Panhard Rods Manta Kadett
HMTurbo
  • 2 months later...
As my car has been lowered, I expect the panhard rod will need to be a bit shorter than usual for correct axle alignment.
Do you know how much adjustment there is with the rose joint to screw it in further and effectively shorten the rod?
  • 1 year later...
  • 1 month later...
Your photos are no longer showing in the forum :-(
Does the rose-joint end fit over the standard chassis mounting, and does the polybush fit over the axle mounting?
For the latter, is the sleeve/shoulder on the axle mount the size needed for the bush to go over it, or does it expect/need a plain bolt?
If that makes sense...
Besides those questions, have you made up a recent batch and have any currently in stock?
