Fitting After Market Steering Wheel. ''pcd Size'' What Fits?
mantapaperman
hi fellow manta lovers i'm wanting to fit a dished steering wheel..either a omp-momo or just a cheap ebay job..
but most i look at say a 6 hole international standard with 35mm centre to centre hole pitch between all 6 holes?? does anyone know if this is correct or what size i should be buying? mines a gte coupe with the irmscher wheel on at present...thanks all
Cant you measure the bolt distance on yours and see if it as the advertised one? in case its not clear the distance would normally be measured across 2 opposites like 12 o clock and 6 o clock etc but 35mm seems too small so they may be saying its 35mm from one hole to the next (like 12 oclock to 1 o clock)
hth
Tony
