Posted
Hi
Looking to get hold of a GTE thermostat housing, that takes the three sensors. Will take it with or without the sensors, just need the housing as mine has cracked.
cheers
Phil
Posted
hi,phil you could be in luck i seem to remember i have more than one spare ,but i shall check first . i take it you more need the lower part as you mention the sensors . paul
Posted
hello,mate i found i had a couple of these .this is a slightly better one its complete has all the sensors already in it , it looks the same as yours. as far as im aware all the 2.0 cih thermostat housings are the same. any good to you ?
Posted
Same pic came up twice,i cant get the hang of that sodding crapbucket thingy, wouldnt it be easier just to copy and post and that.
