Dave Stampy Posted May 7, 2013 Share Posted May 7, 2013 Parts I require to get my car roolling is the D shaped washerthat fits just above the steering colum lower spring, please look through your stuff I know there's got to be one out there, I've been lookibg just over a year for this silly part! Its made me think if its all worth it, that's the main part I really need. Also looking for a set of twin headlights got to be a full set, I see an irmsher set on ebay for 129 but not sure if everythings there as its from germany, I also require a radiator new or good condition. I'm also starting to relise that my botched up sump I made isn't volumeatic enough so I'm thinking of getting the 1800 sump cutting the flange off all the way round and rewelding it back to front in order to fit the v6 engine if anyone could advise whether it will work or not. I've put so much time and effort into this project so far and trying to reach a mile stone where I can start it up and getting it rolling but due to the scaresness of these parts I'm starting to think twice please help, the silly thing is I took the D shaped washer off the car but put it somewhere so secretive I can't seem to find it. Please pm me for a faster transaction or post here for advise cheers. Link to comment Share on other sites More sharing options...
Fermanta Posted May 7, 2013 Share Posted May 7, 2013 I have a column in the shed m8 - if the part is on it you're welcome to it but won't be able to check till weekend. Can you point it out here? Link to comment Share on other sites More sharing options...
stradacab Posted May 7, 2013 Share Posted May 7, 2013 Careful with headlamps from abroadland as they will have the wrong beam pattern (LHD and all that) Link to comment Share on other sites More sharing options...
Dave Stampy Posted May 8, 2013 Author Share Posted May 8, 2013 Hi fermanta look where 10 is its just the little bits above the steering colum is doesn't actaully picture it but it is on there if you can it would be so helpful let me know cheers. Link to comment Share on other sites More sharing options...
Fermanta Posted May 8, 2013 Share Posted May 8, 2013 No problem I'll check at weekend for you - don't spose you could take a pic of where the bit goes as I'm still not that sure - however I do have a complete smashed manta so can part from it if needed.... Link to comment Share on other sites More sharing options...
upk Posted May 8, 2013 Share Posted May 8, 2013 Do you mean the lower colum bearing http://www.s442721238.e-shop.info/shop/article_03320006_0000/Lager-unten-%3CBR%3ELower-bearing.html?sessid=6Zb7t51OULLCxIyADduGLUJjpyG014Dzg9oJVDV1ZNmJiiCulVg7UEgXerMagiDK&shop_param=cid%3D225%26aid%3D03320006_0000%26 Link to comment Share on other sites More sharing options...
Dave Stampy Posted May 11, 2013 Author Share Posted May 11, 2013 Yep that's it cheers guys almost up an firing so many small jobs to do Link to comment Share on other sites More sharing options...
Fermanta Posted May 13, 2013 Share Posted May 13, 2013 Sorry I'm so late getting back to you but have the steering column here. I have a photo of it so if you could tell me roughly where abouts is is or even mark it on the photo I'll get it off tomorow morn & posted. Link to comment Share on other sites More sharing options...
Fermanta Posted May 13, 2013 Share Posted May 13, 2013 Actually I may have been looking at wrong end of column. Is it on this end? Link to comment Share on other sites More sharing options...
Dave Stampy Posted May 14, 2013 Author Share Posted May 14, 2013 Cheers for the help but that one is broken, really appriciate the help though i am in the process of ordering a new set from germany thanks. Link to comment Share on other sites More sharing options...
Fermanta Posted May 14, 2013 Share Posted May 14, 2013 (edited) Ok Dave, sorry. Like I say I also have a complete Manta accident damaged so if you don't get sorted let me know & I'll try and sort it for you, Paul Edited May 14, 2013 by Fermanta Link to comment Share on other sites More sharing options...
Retro Power Posted May 16, 2013 Share Posted May 16, 2013 dave, re. sump, your cheapest option would probably be to sell your 1800 one (good money!) and buy a sump "kit" from yukspeed, that comes as a flat packof laser cut steel bits, then tack it up with your mig welder in roughly the right (backwards) shape/position, then take it somewhere to get it tig welded ( i can do it but long way away!) dont try to mig weld it or it will leak, mig welds always do even if they look perfect, check it with thinners once welded to see if it leaks before you bolt it on Link to comment Share on other sites More sharing options...
Dave Stampy Posted May 16, 2013 Author Share Posted May 16, 2013 Its funny you say that retro power, i got a cavalier steel sump, cut it all the way round just butted it together, fitted a sump nut allwed enough space for the rack but yea i mig welded all the way round and it does leak, ill take it off and give it to my dad hes a sheet metal worker and should have tig, but ive lost atleast a litre or so of volume compared to the original, alloy / steell one do you think it should be suficent enough? Link to comment Share on other sites More sharing options...
