wizbang Posted June 22, 2013 Share Posted June 22, 2013 currently fitted with 1800 box mated to xe and need something stronger would consider any upgrade or conversion type so as to do the job needs to be able to cope with 200 bhp ish Thanks Rob Link to comment Share on other sites More sharing options...
Sutty2006 Posted June 22, 2013 Share Posted June 22, 2013 Have a word with Retro Power on here, they do a conversion kit to run an omega gearbox. Link to comment Share on other sites More sharing options...
rutts Posted June 23, 2013 Share Posted June 23, 2013 you could make a conversion bellhousing to fit the getrag 265 box, I have the parts required just needs alloy welding together. or do a omega mv6 gearbox conversion as stated above. Link to comment Share on other sites More sharing options...
wizbang Posted June 24, 2013 Author Share Posted June 24, 2013 whats involved in the mv6 conversion ? I have seen something re this conversion - do you know whats involved exactly - have you done one ? I was thinking of a type 9 conversion as I have a box and a spare prop - or even upgrading my 1.8 box with a gear kit but can only find a 4 speed tranx kit Link to comment Share on other sites More sharing options...
HutchRoslin Posted June 27, 2013 Share Posted June 27, 2013 I have noticed that my 1.8 gearbox doesn't like being slipped into 2nd when you've revved the t*ts off it in 1st and I won't have anything like 200bhp Link to comment Share on other sites More sharing options...
rutts Posted June 28, 2013 Share Posted June 28, 2013 type 9 box is just as weak as a 1.8 box, mv6 box needs hydrolic clutch an adapter from retro power for slave to work cut down remote for gearstick then get propshaft altered. easier than it sounds. Link to comment Share on other sites More sharing options...
Retro Power Posted June 30, 2013 Share Posted June 30, 2013 whats involved in the mv6 conversion ? I have seen something re this conversion - do you know whats involved exactly - have you done one ? I was thinking of a type 9 conversion as I have a box and a spare prop - or even upgrading my 1.8 box with a gear kit but can only find a 4 speed tranx kit We have fitted upwards of 10 of these boxes, and sold clutch parts to fit over 30 They bolt straight on, you just need to space the clutch release mechanism forwards using one of our spacer kits (or make a spacer yourself and use longer bolts) you will need a custom prop, can advise you will need an electronic speedo or some other solution for speedo as box has no cable output you will need a clutch master cylinder, again can advise as we've done this plenty of times The white ascona 400 in our post pic has an omega box fitted they are good for 400hp, drag starts with toyo 888 tyres, from experience they break with 525hp and the same tyres and starts 1 Link to comment Share on other sites More sharing options...
