Speedometer Drive Gears For Gte
74009
Hi all,
My 1986 GTE speedo is only working intermittently. We think it's to do with the small gears that drive the speedo, located inside the (5-speed) gearbox. It could be the driving gear or the driven gear that's causing the fault - ideally I'm looking for one of each, as I don't want to strip the gearbox down just to find out which one is the problem.
Also looking for a set of gearbox gaskets and a rear crankshaft oil seal.
Anyone have any of these available please?
Thanks
Stuart
If you want a new speedo drive i got mine from here.
http://stores.ebay.co.uk/edelschmiede
check the drive color, mine was the red one on my 240 5 speed box
and gearbox seals from here:
http://www.bearingkits.co.uk/MANTA-5-SPEED-GEARBOX-SEALS/272.htm
and rear crank seal from here:
http://www.vauxhall-car-parts.co.uk/acatalog/VAUXHALL-CRANKSHAFT-REAR-OIL-SEAL---90156857N.html
Just had my 5 speed apart and all cleaned and put all new seals etc.. on it so let me know if there are any other bits you need help with.
ps. also check the speedo cable as sometimes they can be the problem at the box end.
Hope some of this helps
Andy
Edited by 611
They do get full of crap and sometimes they can work a bit loose.
Was rebuilding mine so as I have replaced most of the other parts that move on the car thought best to do that as well :-)
