spiney_norman Posted August 10, 2013 Posted August 10, 2013 Assuming you mean the Recaros, no. 4 bolts holding the seat to the subframe, 13mm if memory serves Quote
MANTAMAN Posted August 10, 2013 Posted August 10, 2013 Undoing any Manta seat from the floor of a Manta B can be a problem, there are four bolts holding down two clips that go over the front bar, bolts that go into captive nuts in the floorpan, these can rust solid and just snap off when you try and undo them, soak them in penertrating oil and wire brush the projecting thread under the floorpan to give you the best chance of removing them. With the seats out, Recaro type seats are held onto the subframe by four allen key type bolts in the slider rails which have to be moved forward and back to get at all four of them. Quote
Aggressor Posted August 11, 2013 Author Posted August 11, 2013 ok thanks lads i know for a recaro seat that needs a subframe was i just wondering how much of a pain it was to do. Quote
