Standard Sunroof Change To Get Rid Of Roof Rot
paul a
Hi all looking at changing the standard sliding sunroof for larger one to get rid of the roof rot around it ?
Car is a 1988 coupe
Can someone tell me how hard the job is and process of doing it regards headlining etc
Im going to get clio sunroof to change it but dont know which one i should try and get hold of ?
also how near to the windscreen can i cut the roof to ?
Any advice much appreciated Paul
If you look at Stradacabs GTE in the project section, it details fitting a Webasto top slider (now known by the brand name Hollandia) they are 820mm wide and will eradicate side rot providing it hasn't gone too badly. There are some other good Clio fitting threads in that section too
