Posted
wanted,lh,passenger side door mirror with adjuster and seal,gasket that goes inbetween the mirror and the door,thanks.
Posted
hi
Do you have one fitted at the moment and need to replace it or are you fitting one for the first time on a car that has not had one ?
hi,i have one with the car but there is no adjuster stalk,handle and no rubber seal,gasket and it was held on with woodwork screws.if i had a seal i could put it back on,the door card is still off for better access.its for a 1985 2.0 gte coupe
Posted
Bung me a PM with a phone number, I know I have spares for these mirrors, I have almost certainly got the parts you need to sort this out properly and I will call you to see what you need.
Posted
hi
i have had a look at my mirror and the mechanism is broken,the glass and backing case are fine,its just the bit that screws on to the car with the adjuster and the rubber seal i need.part number gm16-200 09 288 721 and is attached to the mirror with 1 screw at the bottom,thanks.
  • 1 month later...
