Posted
Does any one know where i can obtain the two rubber seals on top of the brake master cylinder that the plastic reservoir tank sits in?
Mine are leaking on my 1980 Opel Ascona & unfortunately by the time i noticed, the paint had got damaged around the servo area.
Posted (edited)
No they are not in the refurb kit. ( well not in the kit I bought a couple of years back) you can try "PAST PARTS. TEL: 01284 750739" they do an excellent job of refurbushing Master Cylinders. If no luck I have a couple of sets here of good used ones, they do come in two different sizes though, what diameter are the ones you requre. I'm assuming it is an ATE master.
Edited by Julian
Posted
there is two types,
ate and delco, i have the delco ones, that look like rings the other are plug types with small hole.
