Cylinder Head Gasket Set For Manta B 1.8 (1988) & Valves?
Posted
Looking for-
  • head gasket kit for my Manta which seems to be running on 3 cylinders possibly a sticky valve so also needing
  • one inlet & one exhaust valve in case they're needed.
  • Valve stem oil seals (maybe in the kit)
Gary
0141 770 4172
07565 132810
Posted
should still be able to order head gasket sets for this engine through any good motor factor, the 'top end' kit will come with new stem seals.
unless you have burnt an exhaust valve it is unlikely that the valves will be the problem, they even survive snapped cam belts! the valves being vertical above the pistons if they do make contact the hydrolic lifters just get squished!
