hopewer Posted October 30, 2013 Posted October 30, 2013 (edited) Hi, Consolidated list of my last few bits from 86 GTE saloon Standard Steering wheel £5 inlet manifold with sensors but no injectors £10 Several relays one of which appears to be the headlight dip (black with fins) Coil Bosch 1220522014 and the little unit that sits on the bracket - £15 Drivers side mirror £5 Interior clock with orange hands £5 Rear demist and Fan switch £2 each 2 * door latch mechanism's £5 1 door glass think it is the passenger side from memory £10 1 quarter light glass (1 hinge) think it is drivers side from memory £10 One side skirt and opposite upright (spat ?) both slightly damaged on fixing but not visible. £10 pair of front spoiler indicators £10 Original Jack in (ripped) bag. £10 All plus P&P. Cheers, Rob. Edited October 30, 2013 by hopewer Quote
Sutty2006 Posted November 1, 2013 Posted November 1, 2013 Rob. I need an indicator relay. Will get the part number off mine over the weekend so you can see if you have one. Cheers Quote
Chris M Posted November 1, 2013 Posted November 1, 2013 What sensors come with the inlet manifold Rob? Cheers Quote
hopewer Posted November 2, 2013 Author Posted November 2, 2013 What sensors come with the inlet manifold Rob? Cheers Hi, I'm guessing the black bosch one is the throttle position sensor , and the other blue one in the end of the manifold must be air temperature or mixture ? Cheers, Rob. Quote
spiney_norman Posted November 2, 2013 Posted November 2, 2013 If it's on the bulkhead end of the manifold it's the cold start injector. Quote
hopewer Posted November 2, 2013 Author Posted November 2, 2013 If it's on the bulkhead end of the manifold it's the cold start injector. Suspect that is what it is then as I noticed what look like a fitting for an air pipe earlier, so guess that was the fuel feed. Cheers, Rob Quote
hopewer Posted December 1, 2013 Author Posted December 1, 2013 Rob. I need an indicator relay. Will get the part number off mine over the weekend so you can see if you have one. Cheers Did you get sorted with this ? Quote
Sutty2006 Posted December 3, 2013 Posted December 3, 2013 Did you get sorted with this ? didnt get the part number, but still need the relay if you have one? Quote
hopewer Posted December 5, 2013 Author Posted December 5, 2013 didnt get the part number, but still need the relay if you have one? Hi - Sorry not sure which one it would be, I'll try googling some of the part numbers to see if I can work it out. Quote
