Mlocke666 Posted December 31, 2013 Posted December 31, 2013 I know its a long shot but I'll give it a go, need a couple of electrical plugs for my manta project, don't seem to get the time to go up the breakers these days. I'm after 2x bulb holders + plug + short length of cable for the side indicators off an astra mk4, I'm sure there's probably a few vauxhalls with the same style but I know these will definitely fit. Also require the plug + short length of cable for the main power supply of a corsa B power steering unit. Cheers
mantasrme Posted December 31, 2013 Posted December 31, 2013 Can help you with the blue corsa epas plugs as i have them in stock for the epas kits i sell. I take the original wires/terminals out of the plug and supply new lengths of wire with new terminals to refit Normally i provide the plug with 30cm of brown and 150cm of red which is more than enough to reach across the car if needed. But can do any length you want really, can also crimp them up if it helps. They're £7 plus postage for the lot.
andyc Posted December 31, 2013 Posted December 31, 2013 Hi Martyn I'm breaking a MK4 at the moment, PM me your details and i'll sort some out The young man above is your best bet for the EPS plug, i'd suggest you run the Red direst from the battery of the starter with a 50map maxi or midi fuse I find these guys have quite alot to offer. http://www.simtekuk.co.uk/ http://www.vehicle-wiring-products.eu/VWP-onlinestore/home/homepage.php http://www.autoelectricsupplies.co.uk/ Cheers Andy
Mlocke666 Posted December 31, 2013 Author Posted December 31, 2013 Mantasrme, I'll take you up on that offer, I'd need a metre length of cable on it with ring terminals (I'll let get back to you with the size). Andy, that's great, I'll pm you now.
mantasrme Posted December 31, 2013 Posted December 31, 2013 Mantasrme, I'll take you up on that offer, I'd need a metre length of cable on it with ring terminals (I'll let get back to you with the size). No problem, i have ring terminals for 8mm or 6mm I also have inline fuse holders with fuses and terminals to fit the wire like these for £3 if you don't already have one
