Posted
Can you remove the stick and top up the oil through the top on a mk1 cavalier? Or is the normal top up place not a massive ballache? I seem to have a slight leak and am worried about how much might be left in it!
Posted
Is it the 4 or 5 speed box Dave? If it's the 5 speed then it's filled through a drain plug on the driver's side, easiest to use a length of pipe to fill it. Think the 4 speed box is similar but I can't remember, I can check tomorrow.
Posted
It's a 4 speeder - my second gear seems to vibrate midrange and it makes a nasty noise in reverse, on looking at the suspension before I spotted that the gearbox was quite wet so I'm concerned it could be lacking in slippy juice
