vealmonkey Posted February 1, 2014 Posted February 1, 2014 any one run bike carbs and run the standard ecu to run the dissy only ,will this work , whats the best bike carbs to put on and what needs to be moded with them , for road use ,would be happy with 160/170hp 1 Quote
MB15 Posted February 1, 2014 Posted February 1, 2014 (edited) You wont need the ecu mate if using carbs? Borg bros do a manifold on their site for bike carbs ect , mite be worth a Google Tain Show this year mate? Edited February 1, 2014 by opeldvd11 Quote
vealmonkey Posted February 1, 2014 Author Posted February 1, 2014 i dont want to run a stand alone dissy ECU , but have th ECU for the redtop thot i could save some $$ dooing it this way if it works , this is going in to a nother manta a i got a yellow one with a black stripe came from inverness in 2005 , you mind it , if shes on the road i will take her to tain 1 Quote
vealmonkey Posted February 11, 2014 Author Posted February 11, 2014 any one run bike carbs , and std ECU to run the spark ???? Quote
simon p Posted February 11, 2014 Posted February 11, 2014 Not sure but it may be worth checking the members section Quote
Retro Power Posted February 12, 2014 Posted February 12, 2014 R1 carbs plus a cavalier 1600 8 valve mechanical dizzy recurved to suit the xe. carbs need jets drilling. I have that setup on an xe of my own (I didn't do it, I bought the car that way) and to be fair it makes 210hp flywheel and has a great torque curve. Was set up by Russ Lyons at Torque Tune. I would always go for throttle bodies and aftermarket ecu if I were planning the job. Using the motronic for ignition seems a bit of a bodge. It would technically work I'm sure, but no idea what timing it would run as it would need the airflow input etc, almost certainly would be in limp mode at best. 1 Quote
dynamytedan Posted February 16, 2014 Posted February 16, 2014 ive got a nodiz unit to do the sparks with , programable maps,bluetooth , uses gm sensors and the tps from the bike carbs , you can add manfold pressure and air temp sensors also . i havent heard of using the standard ecu for spark ...it might not be perfect the way it is as you cant change the advance to suit carbs . Quote
