robah Posted April 21, 2014 Share Posted April 21, 2014 Hi I am looking for a Brake Distribution Valve for a Manta GTE standard Servo setup. I am unsure if mine is faulty as the rear brakes stay on when pedal is depressed. It is the valve that sits on the L/H chassis rail. Thanks Link to comment Share on other sites More sharing options...
Snowy Posted April 21, 2014 Share Posted April 21, 2014 It could also be the rear flexi hose collapsing internally causing it to act as a one way valve. Link to comment Share on other sites More sharing options...
mantasrme Posted April 21, 2014 Share Posted April 21, 2014 I have a couple of them laying around as i normally remove them and run without it. You can have one for the price of postage, or if you're not in a hurry i can get it across your way to Rutts as he's coming across to me sometime soon They are actually a load limiting valve for the rear brakes, when the brake pressure gets above a certain amount it lowers the rear pressure to stop the rear brakes from locking up. Never had a problem locking the rears with this removed with any front brakes, and discs or drums on the rear. Unless i pull the hydraulic handbrake of course 2 Link to comment Share on other sites More sharing options...
rutts Posted April 22, 2014 Share Posted April 22, 2014 same as snowy says rear flexy f**ked. will pick up valve though if required before next pub meet. 1 Link to comment Share on other sites More sharing options...
garymanc Posted April 22, 2014 Share Posted April 22, 2014 i have posted Rob one out today 1 Link to comment Share on other sites More sharing options...
robah Posted April 22, 2014 Author Share Posted April 22, 2014 Thanks for the replies guys. I have got new rear axle hoses, banjos and nuts arriving tomorrow. One of the guys in Germany told me about a damper valve in the master cylinder for the drum brakes, I should have removed it when fitting the rear discs. Gary I will send PayPal now, completely forgot. 1 Link to comment Share on other sites More sharing options...
robah Posted April 22, 2014 Author Share Posted April 22, 2014 I have a couple of them laying around as i normally remove them and run without it. You can have one for the price of postage, or if you're not in a hurry i can get it across your way to Rutts as he's coming across to me sometime soon They are actually a load limiting valve for the rear brakes, when the brake pressure gets above a certain amount it lowers the rear pressure to stop the rear brakes from locking up. Never had a problem locking the rears with this removed with any front brakes, and discs or drums on the rear. Unless i pull the hydraulic handbrake of course that's the valve he was on about. Cheers for that Dave. Link to comment Share on other sites More sharing options...
