Scribe of Lincoln Posted June 15, 2014 Share Posted June 15, 2014 Does anyone have a Headlamp Wiper Solonoid that they are prepared to part with please? This sits on the inside of the front panel on the drivers side (the round silver thing with the washer pipes running to and from it to use the technical term). Thanks Link to comment Share on other sites More sharing options...
Scribe of Lincoln Posted June 16, 2014 Author Share Posted June 16, 2014 Anyone please? I'm re-plumbing the bronze B and it would be good to fix this after 21 years.... Link to comment Share on other sites More sharing options...
Julian Posted June 16, 2014 Share Posted June 16, 2014 A solonoid with pipes running out of it Can you put a photo up of this component.? Link to comment Share on other sites More sharing options...
shaggy Posted June 16, 2014 Share Posted June 16, 2014 I have one but not sure if it works, Give me your address and i will send it off to you and you can try it. Link to comment Share on other sites More sharing options...
garymanc Posted June 16, 2014 Share Posted June 16, 2014 A solonoid with pipes running out of it Can you put a photo up of this component.? http://forums.mantaclub.org/topic/35274-headlight-wash-soleniod/?hl=solenoid pic on this thread , gave the one i had away though Link to comment Share on other sites More sharing options...
andyc Posted June 16, 2014 Share Posted June 16, 2014 Hey Ben If you have no joy with the above let me known. The Manta ones are NLS but the Mk2/3 Cavalier, Carlton & Senator used the same setup but the bracket is different. I used one of these on the last one i done and just made a simple clamp bracket, you have me number Cheers Andy Link to comment Share on other sites More sharing options...
Scribe of Lincoln Posted June 18, 2014 Author Share Posted June 18, 2014 Hey Ben If you have no joy with the above let me known. The Manta ones are NLS but the Mk2/3 Cavalier, Carlton & Senator used the same setup but the bracket is different. I used one of these on the last one i done and just made a simple clamp bracket, you have me number Cheers Andy Cheers mate. I'll try the second hand one first that Shaggy has offered me - if it doesn't do the trick I'll give you a call. Bonnet is away being shot blasted and resprayed at the moment so no hurry! Link to comment Share on other sites More sharing options...
toj28 Posted June 30, 2014 Share Posted June 30, 2014 Im sure i have 1 Link to comment Share on other sites More sharing options...
