Weber Dgv Carburettor - Solex Replacement Fits Many Opel Models - £49
Beaker
On offer is a Weber DGV Carburettor, a type fitted as original equipment to many of the Ford cars of the 1970s. They also make ideal replacements for the temperamental Solex DIDTA carburettor fitted to Opels of the same era.
Unlike the original Solex carburettor, with the Weber DGV model you have full control over the choke for easier cold starting and improved fuel consumption. It is a compound carburettor with a small bore section for economical running and a larger bore which opens progressively for full power when you need it. This combination means that you get the best of both worlds; a boost in both performance and economy too.
Most importantly spares are relatively cheap and plentiful, making a cinch of servicing and modification. You can even install the Weber DGV carburettors with the original equipment air cleaner, assuming you can source the correct oval adapter plate, which is not included in this sale.
I am giving priority to OMOC members and friends by listing here first, but after that it will be offered on eBay and elsewhere. Send a message or leave a comment if you have any enquiries. Click to buy here http://www.markkinnon.com/2014/08/for-sale-weber-dgv-carburettor-49.html
