Brown Job Posted August 22, 2014 Share Posted August 22, 2014 Need to replace the gearbox mount on my car, was getting rough when I fitted it and hasn't improved with time. seem to remember you can buy (used to be able to buy?) these new but for silly money, about £60, which was way OTT for a bit of injection moulded rubber and a bolt. Any news since then? Any knocking around? BJ Link to comment Share on other sites More sharing options...
CRAZYDAVE Posted August 22, 2014 Share Posted August 22, 2014 What you need is one of these http://www.ebay.de/itm/Dampfungsblock-Getriebeaufhangung-hinten-5-Gang-Getrag-240-265-cih-Automatik-/201071609106?pt=DE_Autoteile&hash=item2ed0cd4512 its an aftermarket alternative for a fraction of the price of a genuine one and good quality. The seller is great to deal with i've had a lot of bits from him in the past. He also does the same part as a kit including the metal bracket and new bolts too http://www.ebay.de/itm/Set-Getriebeaufhangung-mit-Dampfungsblock-hinten-5-Gang-Getriebe-Getrag-240-cih-/201071609266?pt=DE_Autoteile&hash=item2ed0cd45b2 Link to comment Share on other sites More sharing options...
Ems Posted August 22, 2014 Share Posted August 22, 2014 That's the one I've just fitted to my Manta. Link to comment Share on other sites More sharing options...
paulmanta Posted August 22, 2014 Share Posted August 22, 2014 I have been using LandRover engine mounts for years now. Britpart number NRC2054. Use two, support the gearbox in position with a jack and remove the old mount and crossmember, then screw the two land rover mounts into the gearbox and then refit the crossmember to obtain the new hole positions for the lower threads. The new mounts will need spacing, I normally get a thick bit of plate and weld it to the cross member, I then drill the holes for the thread in this. Total cost, of about £8. 1 Link to comment Share on other sites More sharing options...
opelmantagsi Posted August 23, 2014 Share Posted August 23, 2014 Thomas also has a very good online shop. He is a great guy to deal with http://www.edelschmiede.com/ 1 Link to comment Share on other sites More sharing options...
611 Posted August 23, 2014 Share Posted August 23, 2014 I agree, got loads of parts from him (including one of those!) Very helpful and quick on delivery. And his shop has so many parts its hard not to buy more bits!! These guys also have some great stuff, but a bit trickier to get bits as they only take a banks transfer. But lots of good stuff. Andy 1 Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted August 23, 2014 Share Posted August 23, 2014 (edited) BLOCK, DAMPER, REAR MOUNTING (GETRAG 240/264/265) available Genuine and NEW!! (offer price 60 Euros posted normal way/70 Euros posted registered) (Please refer that you are from this forum member) (for the moment 38pcs avail. in offer stock) Simple mail (no tracking 10-12 days delivery) Registered AIR mail (with tracking No 4-6 days delivery) Till 3 pcs order the delivery costs remain the same Edited August 23, 2014 by OPEL PARTS GREECE Link to comment Share on other sites More sharing options...
Brown Job Posted August 23, 2014 Author Share Posted August 23, 2014 What you need is one of these http://www.ebay.de/itm/Dampfungsblock-Getriebeaufhangung-hinten-5-Gang-Getrag-240-265-cih-Automatik-/201071609106?pt=DE_Autoteile&hash=item2ed0cd4512 its an aftermarket alternative for a fraction of the price of a genuine one and good quality. The seller is great to deal with i've had a lot of bits from him in the past. He also does the same part as a kit including the metal bracket and new bolts too http://www.ebay.de/itm/Set-Getriebeaufhangung-mit-Dampfungsblock-hinten-5-Gang-Getriebe-Getrag-240-cih-/201071609266?pt=DE_Autoteile&hash=item2ed0cd45b2 Wow, thousands of replies to choose from! This sounds good, so instead of a sort of triangular bit of wobbly rubber you mount these 2 side-by-side round bits on a plate, and the mount holes/bolts all match? I ask because my technical german is a bit rusty these days, rather like my floorpan. BJ Link to comment Share on other sites More sharing options...
Brown Job Posted August 23, 2014 Author Share Posted August 23, 2014 Thomas also has a very good online shop. He is a great guy to deal with http://www.edelschmiede.com/ I like this, I can read pictures in German! BJ Link to comment Share on other sites More sharing options...
Brown Job Posted August 23, 2014 Author Share Posted August 23, 2014 I have been using LandRover engine mounts for years now. Britpart number NRC2054. Use two, support the gearbox in position with a jack and remove the old mount and crossmember, then screw the two land rover mounts into the gearbox and then refit the crossmember to obtain the new hole positions for the lower threads. The new mounts will need spacing, I normally get a thick bit of plate and weld it to the cross member, I then drill the holes for the thread in this. Total cost, of about £8. I like this idea too, Paul. Cheap. Cheap is always good. And my mate is a Landy enthusiast, so it's a live possibility. BJ Link to comment Share on other sites More sharing options...
opelmantagsi Posted August 23, 2014 Share Posted August 23, 2014 I like this, I can read pictures in German! BJ Google chrome auto translate. Changes the German writing to English. Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted August 24, 2014 Share Posted August 24, 2014 (edited) 5 pcs offer at 35 Euros per item/ 50 Euros posted/item Edited August 24, 2014 by OPEL PARTS GREECE 1 Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted September 11, 2014 Share Posted September 11, 2014 Stock became limited Link to comment Share on other sites More sharing options...
