Mk1 Cav/car'b Manta Ignition Coil
davo
As they say 'Every Little bit helps' so might be able to widen your search as the Cavalier mk1 Manual states the coil for 1.6 / 1.9 / 2.0 Engine is same part number for a Delco.
The first link above says the Coil is as per 3474200 GM so think it might fit but 2nd one is a red herring.
See this E-Bay listing - it quotes the Part Number your require but also lists more cars it also fits - it's NGK Coil - expensive due to postage but .....
http://www.ebay.de/itm/OPEL-ASCONA-A-B-CORSA-A-KADETT-C-D-E-REKORD-C-D-81-86-87-88-NGK-ZUNDSPULE-/291252317635?pt=DE_Autoteile&hash=item43cffdadc3#shpCntId
Edited by NEIL W
