Irmscher Distributor For 2.0E
RallyManta
Hi
I'm looking for an Imrscher sport distributor for 2.0E. These distributors were fitted on the Manta i200.
Irmscher number: 0231170235
Bosch number: 0237020049
I know there are new (quite expensive) ones available, but it'll do great with a used one.
Best regards
Bjorn
As far as I understood it the only reason they were special was that they only had vacuum advance not mechanical advance.  Either disable your weights or get hold of a 2.4 frontera dizzy and remove the solid shaft, then put the shaft in yours.  The vac advance will still work as that is mounted on the case not the shaft and moves the pickup around in relation to the fixed rotor vane on the shaft.
Might even be able to put the vac advance in a 2.4 dizzy, its a bare unit with only a shaft and a rotor arm so the case might need a blank plug or two knocked out.
Could be a cheaper way to do what you want.
