Couple Of Pieces Needed
shooie811
Both 1x upper (Metal) and 1x lower (with plastic) steering shaft bearings & the 1x damper block crossmember are available to our stock
All of them at 125 Euros + shipment/payment costs in NEW
All of them at 80 Euros + shipment/payment costs in USED
If you may not be able to locate them locally send pm for more details
Edited by OPEL PARTS GREECE
The Upper bearing is the same as fitted to the Corsa B columns, I have a whole load of them from the Epas columns i've stripped to make power steering columns.
They are not new but are from younger and lower mileage cars than the original manta one.
For the lower bearing as Andy says if you have all the parts and the bearing surfaces aren't pitted then they can be rebuilt using new grease and a load of new ball bearings.
That is what i do to any i have in for work, i'll try to remember to check what size bearings i use.
If you want an upper one they are £2 plus postage
Also have some used crossmember mounts kicking around.
