Borbet Wheel Size
stephenlevin1620
The A look good, I have a set on my V8, I went with 16s all 4 the same width and offset.  I think 8 wide it was a few years and many projects ago so I would have to look at the wheels to say for sure !,
I made up spacers to get them where I wanted them in the arches and I think its a sensible idea to use proper hub-centric spacers that fit in the wheel and onto the hubs from and rear.
Edited by paulmanta
So I've got my eyes on a set of genuine borbet A 16inch 4x100 et15 9J & 7.5J staggered wheels inc flatcaps and lockers. Will these fit my exclusive??
Just to let you them ones on ebay have been repainted so there not the chrome rim? Just in case you didn't know!
  • 10 months later...
I had Azev A's on mine, 7.5x16 et20 on the front, 195/45x16 tyres, no problem with standard arches. 9x16 et15 on the back with 205/45x16, had to roll the arches slightly and weld an adjuster into my pan hard rod because mine's very low. Arches may need no mods if not lowered. Will see if I can find a photo.
  • Thanks 1
  • 2 years later...
Hi iv just joined the site
Im thinking to buy a 2.0 manta gte 1986 hatchback and i would like to also buy the borbet 16inch wheels as the same fitment above....I don' have the money to lower it... and niether do I want to do the work on the arches....would the wheels still look good if I didn't' lower the manta and would they still be in clearance from any rubbing
Yr answer will be a great help
My personal opinion is it will look shit if it's not lowered with the big 16 inch borbets.
Widest you'll be able to go without arch mods is 7.5 but you'll need a positive offset of around 20/25mm.
if I were you I'd see if you could borrow some 16 inch wheels off a mate or someone to try on before you commit to buy anything.
Also, a set of lowering springs aren't expensive, if you're on a budget there will be nothing wrong with the likes of these https://www.ebay.co.uk/itm/DIRENZA-LOWERING-SPRINGS-SUSPENSION-40mm-OPEL-VAUXHALL-MANTA-B-ASCONA-B-B-CC/151520944257?epid=2185681113&hash=item23475a2081:g:FjUAAOSwQiRUlEnb
Biffy nice to meet you and thank you for your reply if I went for the big borbet (which i may do so) would those springs 40mm drop do the job?....
Is trimming the arch better or rolling it hoping the paint dont crack
You also quoted on the previous post that u had to weld a adjuster to the pan..would I need to do this?
Chris from Coventry will be taking on the work as i live in bham iv been recommended by Simon from Suffolk!
Has any 1 tried those bolt on plastic Arches?
Or get Uncle Angle Grinder out and chop a coil or two out off the ones that you have to see if you like the new ride height. If not, you can cheaply pick up a new or used original height replacement.
Just make sure that you cut the coils in the same place as the original ones end (if that makes sense), so that you can locate in the spring 'cups' in the same way/positions.
Edited by IanMc
Hi ian...soo your saying cut the springs soo I can see what height I prefer for the car to sit on... that way I can order the the following lowering springs?
Yes, or you could decide to leave them like that and save yourself some money....
I was hoping they fit without lowering them or to mess with my arches let' see how I get on??
Anyway iv jus received my delivery I have a set of borbet rims as described above... near enuff brandnew 1 way or the other they gona have to go on!:unsure:
