Redrobie Posted February 8, 2015 Share Posted February 8, 2015 Hi, I recently bought some twin light conversions for my Manta. One is an Irmscher, the other a copy. The light units clip on to the adjusters using a kind of socket fitting. They simply clip.on, no trims or lock rings or anything. Anyway I am looking to find replacement outer units so I can swap from H1/H1 to H4/H1. Can anyone on here help or suggest a car which would have used these style of light unit fixing. Thanks, Bob. Link to comment Share on other sites More sharing options...
Jenson Posted February 8, 2015 Share Posted February 8, 2015 Hi mate Lucas from a ford Capri mk3. Had many problems with these twin headlamps myself the problem being there are so many different types of fixings . Good luck. Link to comment Share on other sites More sharing options...
rutts Posted February 9, 2015 Share Posted February 9, 2015 jaguar xj40 are Lucas flat lens the same fitting lugs attached at 120 degrees apart. can be found at any jaguar breakers I use Kelly jaguar breakers in Wrexham wales great guys and usually good prices. don't know if they do postage though . the fittings can be made using stainless 4mm rod cut a groove in at an angle push onto light lug araldite it to light, fit a stainless spring onto bolt fit in light holder/pod use stainless nuts and washers the total cost is around £10. how too on here if you do a search Link to comment Share on other sites More sharing options...
