mantasrme Posted April 7, 2015 Share Posted April 7, 2015 (edited) Having a clear out of a few things. An original stereo blanking plate with all 4 clips still attached (oe equipment on base spec cars) £10 SOLD A pair of aftermarket alloy window winder handles, they are the earlier multispline type £40 I do also have a pair of early multispline window regulators so on a late car Just fit these and the alloy winders will fit £10 Fiberglass Quad lights, Cibie curved glass lamps with H4 outer, H1 inner rust in the reflectors need painting £55 Pair of used Audi discs, machined and re-drilled. Were fitted for about 6 months of light use before upgrading to larger brakes £35 SOLD Reconditioned steering rack done about 9000 miles since professional full rebuild (removed to fit a quickrack) £35 inner wing turret tops (for double skinning reinforcement) £10 Standard pedal box (clutch and brake pedals) £15 panhard rod £5 Propshaft U clamps with tabs and nuts £10 pair 3.7 crown wheel and pinion £15 5 speed tunnel top (cut out well around the seam) £10 SOLD White Gt/e side skirts £40 pair (collection only!) 1.8 water pipe set (including alloy piece) £20 Hatchback shelf supports in black £5 pair All parts are in Harrogate and collection is fine, or i will post and combine costs for multiple items. Pm me for more details Edited April 12, 2015 by mantasrme Quote Link to comment Share on other sites More sharing options...
CRAZYDAVE Posted April 7, 2015 Share Posted April 7, 2015 PM Sent Quote Link to comment Share on other sites More sharing options...
Snowy Posted April 7, 2015 Share Posted April 7, 2015 Having a clear out of a few things. An original stereo blanking plate with all 4 clips still attached (oe equipment on base spec cars) £10 SOLD A pair of aftermarket alloy window winder handles, they are the earlier multispline type £40 I do also have a pair of early multispline window regulators so on a late car Just fit these and the alloy winders will fit £10 Fiberglass Quad lights, Cibie curved glass lamps with H4 outer, H1 inner rust in the reflectors need painting £55 Pair of used Audi discs, machined and re-drilled. Were fitted for about 6 months of light use before upgrading to larger brakes £35 Reconditioned steering rack done about 9000 miles since professional full rebuild (removed to fit a quickrack) £35 inner wing turret tops (for double skinning reinforcement) £10 Standard pedal box (clutch and brake pedals) £15 panhard rod £5 Propshaft U clamps with tabs and nuts £10 pair 3.7 crown wheel and pinion £15 5 speed tunnel top (cut out well around the seam) £10 White Gt/e side skirts £40 pair (collection only!) 1.8 water pipe set (including alloy piece) £20 Hatchback shelf supports in black £5 pair All parts are in Harrogate and collection is fine, or i will post and combine costs for multiple items. Pm me for more details Can I have the audi discs and five speed tunnel top. Could you give me a price for posting. Thanks Quote Link to comment Share on other sites More sharing options...
mantasrme Posted April 7, 2015 Author Share Posted April 7, 2015 PMs sent Quote Link to comment Share on other sites More sharing options...
yeti132 Posted April 7, 2015 Share Posted April 7, 2015 Are the Audi disc front or rear if rear would be intrested Quote Link to comment Share on other sites More sharing options...
Irmscher Man Posted April 8, 2015 Share Posted April 8, 2015 I would be interested in the Quads, if they are still available. I'm in no great rush though, so would be more than happy to wait until Billing to pick them up, if that is okay with you? Quote Link to comment Share on other sites More sharing options...
