manta81 Posted May 6, 2015 Share Posted May 6, 2015 (edited) does anyone have two good front cross member braces to fit a 1980 manta coupe 2.0 , mine have weakened where the bush go after shot blast so I need stronger ones. 07920197172 or email clivemoss@yahoo.com Edited May 6, 2015 by manta81 Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted May 6, 2015 Share Posted May 6, 2015 Front crossmember is available in genuine and NEW Pm for more details Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted May 6, 2015 Share Posted May 6, 2015 1 Link to comment Share on other sites More sharing options...
manta81 Posted May 6, 2015 Author Share Posted May 6, 2015 sorry you didn't read the add right I don't want the crossmember I need the brace bars Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted May 6, 2015 Share Posted May 6, 2015 sorry you didn't read the add right I don't want the crossmember I need the brace bars Sorry!! Link to comment Share on other sites More sharing options...
Redrobie Posted May 6, 2015 Share Posted May 6, 2015 Do you mean the pressed bars from the Swan necks forward? If so I might have a pair if I can get them off before the car is scrapped. Bob Link to comment Share on other sites More sharing options...
Snowy Posted May 6, 2015 Share Posted May 6, 2015 I have a few cross members fully stripped. Which bit do you need? The wishbone or the link bar? Thanks Link to comment Share on other sites More sharing options...
paulmanta Posted May 6, 2015 Share Posted May 6, 2015 After a bit of thinking it was the main crossmember you were after and then reading that its not that (as Anthony from Greece had posted) I think you need the subframe crossmember braces, the ones that run from the main subframe (that holds the engine up and the suspension attaches to) to the chassis on either side, they have bushes in them where they meet the chassis. If so I might have a pair but would need to look at condition. Link to comment Share on other sites More sharing options...
manta81 Posted May 6, 2015 Author Share Posted May 6, 2015 on the manta you have two brace bars if you read the Haynes manual it states brace bars so I assume that what they call them anyhow I need two good ones must have all the metal in the hole where the bush fits . from the back of the cross member it bolts onto then goes to the inside of the chassis leg where they bolt on with rubber bushes . Link to comment Share on other sites More sharing options...
manta81 Posted May 6, 2015 Author Share Posted May 6, 2015 After a bit of thinking it was the main crossmember you were after and then reading that its not that (as Anthony from Greece had posted) I think you need the subframe crossmember braces, the ones that run from the main subframe (that holds the engine up and the suspension attaches to) to the chassis on either side, they have bushes in them where they meet the chassis. If so I might have a pair but would need to look at condition. please do let me know condition Link to comment Share on other sites More sharing options...
manta81 Posted May 6, 2015 Author Share Posted May 6, 2015 I have a few cross members fully stripped. Which bit do you need? The wishbone or the link bar? Thanks cross member brace bars but need to be rot free where they have the rubber bush fitted Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted May 7, 2015 Share Posted May 7, 2015 (edited) .......... Edited May 7, 2015 by OPEL PARTS GREECE Link to comment Share on other sites More sharing options...
