Jimmytesco Posted June 9, 2015 Share Posted June 9, 2015 Hey all. I've put a mante gte engine into my Chevette and need to wire up the 3 pin dizzy to module etc as can't source a loom :-(. Anyone any idea how to do this? I have a diagram but unsure as to what wires go where on the dizzy 3 pins Many thanks. Jim Quote Link to comment Share on other sites More sharing options...
paulmanta Posted June 9, 2015 Share Posted June 9, 2015 You only need a little "sub loom" to link the dizzy and coil and ignition module together, I think I might have one spare here if you don't have one. You then just join the + to it and earth it out, if you have a rev counter you T off the green wire. Quote Link to comment Share on other sites More sharing options...
Jimmytesco Posted June 10, 2015 Author Share Posted June 10, 2015 That b perfect if u have one pal. How much posted to Belfast please. Jim Quote Link to comment Share on other sites More sharing options...
paulmanta Posted June 10, 2015 Share Posted June 10, 2015 PM me your address and I will find out how much post is. Also, I will look out a good one in my wire box and let you know if I 100% have one ! Do you have the module ? if so can you tell me how many pins it has ? Quote Link to comment Share on other sites More sharing options...
Jimmytesco Posted June 10, 2015 Author Share Posted June 10, 2015 Hey again. The module has 7 pins sir. But my friend reckons only 6 used but could b wrong. My postcode is bt38 8uy Many thanks jim Quote Link to comment Share on other sites More sharing options...
paulmanta Posted June 10, 2015 Share Posted June 10, 2015 Ok, 7, your mate is right, only 6 are used. Quote Link to comment Share on other sites More sharing options...
Jimmytesco Posted June 12, 2015 Author Share Posted June 12, 2015 Any luck with this sir ? :-) Quote Link to comment Share on other sites More sharing options...
mantadoc Posted June 12, 2015 Share Posted June 12, 2015 If wired like most points cars....... Nip the translucent resistance wire off against the terminal, leaving the terminal on the black wire (if there is a translucent yellow / orange and black crimped in the same terminal) and insulate the cut end. The black is usually a 12V while cranking from starter solenoid to ensure good power under cranking and don't forget to add another ignition position 2 live to power the coil pack / amp when key on and engine not cranking (run position) Quote Link to comment Share on other sites More sharing options...
paulmanta Posted June 14, 2015 Share Posted June 14, 2015 Yup ! Quote Link to comment Share on other sites More sharing options...
mantadoc Posted July 5, 2015 Share Posted July 5, 2015 Moving from Projects to Basic Tech Help as would seem to eb the correct section Quote Link to comment Share on other sites More sharing options...
