opelman Posted June 18, 2015 Share Posted June 18, 2015 GTE Hatch with 20xe engine used for track days, 650lb linear front springs, 180lbs linear rear springs with a set of Bilstein sport dampers, rear end is polybushed, 16mm rear anti roll bar. Despite these upgrades the back end still leans a fair bit when cornering with a tendancy to understeer, in terms of stiffening the back I am not sure where else to go form here, any ideas please ? Quote Link to comment Share on other sites More sharing options...
evo3000 Posted June 21, 2015 Share Posted June 21, 2015 GTE Hatch with 20xe engine used for track days, 650lb linear front springs, 180lbs linear rear springs with a set of Bilstein sport dampers, rear end is polybushed, 16mm rear anti roll bar. Despite these upgrades the back end still leans a fair bit when cornering with a tendancy to understeer, in terms of stiffening the back I am not sure where else to go form here, any ideas please ? sounds like you may need to lower the suspension to eliminate the body roll,mine has has 40mm spax progressive springs on and its totally planted in the bends. Quote Link to comment Share on other sites More sharing options...
MANTAMAN Posted June 23, 2015 Share Posted June 23, 2015 sometimes the Panard Rod assembly can act like a lever in certain circumstances. If you are good at fabrication it would be a not too difficult project to make a Watts linkage for the rear axle, probably best to make a mounting for the short link attached to the bodyshell, the outer ends of the arms attaching to the axle, that way you wouldn't have to find a way of making a strong diff cover. 1 Quote Link to comment Share on other sites More sharing options...
