1988 White Gte exclusive Coupe £4995
latest mot
ate of test:
03/07/2015
Certificate issue refused (Fail)
Odometer reading:
89,478 Miles
Test number:
587314385101
Test station name:
MIATA AUTO SERVICES
Test station number:
V108579
Test station telephone number:
01142511610
Test class:
IV
Reason(s) for refusal to issue Certificate
Battery insecure (1.9.1)
Rear fog lamp tell tale missing (1.3.1b)
Nearside Headlamp insecure (1.7.3)
Offside Front inner wing Vehicle structure has excessive corrosion which adversely affects braking or steering (6.1.A.1)
Offside Rear inner sill Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Nearside Rear inner sill Vehicle structure has an unsatisfactory modification, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Offside Rear inner sill Vehicle structure has an unsatisfactory modification, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
Offside Front Brake hose excessively damaged (3.6.B.4d)
Offside Front Fuel hose insecure (7.2.1)
Exhaust emissions carbon monoxide content excessive (7.3.B.1a)
Advisory Notice issued
Nearside Brake cable has wires broken but is not significantly weakened (3.5.1b)
Service brake: service brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
Parking brake: parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
Brakes imbalanced requirements only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.5b)
Unable to fully inspect under body / chassis due to excessive underseal/sealer apllication
Engine oil leak
Advise repair to fuel pump mounting bracket
Front radiator cross member corroded
Date of test:
24/07/2015
Certificate issued (Pass)
Odometer reading:
89,478 Miles
Test number:
187845505218
Test station name:
MIATA AUTO SERVICES
V108579
01142511610
Test class:
IV
Test expiry date:
23/07/2016
Advise brake service/repair
Unble to fully inspect chassis/floor area due to excessive bodysealer & undersealer application
As a trader who deals with mot tests day in day out I can tell you that car isn't a good one from that mot info .
ive no problem at all with the guy making a profit - again I seek to do that day in day out - but the car HAS TO BE RIGHT
unable to inspect floor/underside of vehicle due to excessive underseal application !  in manta speak that's its furbarred underneath and make the fastest exit possible. still with your contents of your wallet intact......  lol I only came on here to see what had been said,after I had just viewed it on e bay. I must admit I was very amused by the only one of its kind on the road.... oh well one born every minute .
Un-earth any bodges so you know exactly what is what, buy this for a sensible price ( a subject of huge debate ) and this Manta would make a good staring point for someone.
It may need welding underneath but you could have a very presentable Manta on the road without a total restoration.
But it is the question of what is a sensible price for which the true condition of the Manta would have to be known.
fails its Mot as its buggered.......turns up again 20days later having not covered a single mile and passes after being "repaired"
and hey presto it appears on eBay as a rare classic!
Could have had the work done at the garage/mot station. had a massive bill for labour, and has to rake it back somehow.
Edited by Julian
