halley cockburn Posted March 12, 2016 Share Posted March 12, 2016 Hi there can anyone give me advise on removing an old radiator , as my old one has black rubber type bush at side ,of radiator and wonder if i just lever the rubber off and reveal a nut or bolt thanks Quote Link to comment Share on other sites More sharing options...
Snowy Posted March 12, 2016 Share Posted March 12, 2016 If you look at the bottom of the radiator, from underneath the car, you will see a support with a 13my headed nut. Undo this, the top and bottom hose and it will pull out. Quote Link to comment Share on other sites More sharing options...
Snowy Posted March 12, 2016 Share Posted March 12, 2016 Ignore the two rubber supports on the sides. Quote Link to comment Share on other sites More sharing options...
halley cockburn Posted March 12, 2016 Author Share Posted March 12, 2016 Thank you again will do this tomorrow cheers Quote Link to comment Share on other sites More sharing options...
MANTAMAN Posted March 12, 2016 Share Posted March 12, 2016 Carefull with the bottom nut, it is on a stud that is part of a bonded rubber mount, if you apply a lot of force to a rusty nut (very likely rusty due its postition) instead of unscrewing the nut the rubber with seperate, (this may have happened anyway with age) I don't know where you can get a replacement rubber mount. Quote Link to comment Share on other sites More sharing options...
Snowy Posted March 12, 2016 Share Posted March 12, 2016 You can buy them from any decent factors or kit car supplier such as car builder solutions Quote Link to comment Share on other sites More sharing options...
D85CGV Posted March 20, 2016 Share Posted March 20, 2016 Hello Halley. Not been in the forum for a wee while I saw your reply to the Manta in Helensburgh and that you're in Edinburgh. I also spotted you were looking for a radiator. I have one if you're still interested. I'm in Edinburgh are regularly so could pop through with it if needed. Cheers Davy Quote Link to comment Share on other sites More sharing options...
