Steves Posted March 28, 2016 Share Posted March 28, 2016 For Sale Engine Parts from Rally OPEL Manta CIH · Ported Cylinder Head £120 with Ultra big Stainless Steel Valves, Kent OP 264 race camshaft, Kent solid followers, Kent HD valve springs and Bronze valve guides · Kent Vernier pulley £25 · Nearly New duplex timing chain and crank pulley £20 · Adjustable RIESSE Motorsport Chain Tensioner. £10 · “2.4 INJECTION” Polished Alloy Rocker Cover. £20 · Timing cover Assembly with HP Oil Pump £20 · Alloy Inlet manifold for twin 45mm Weber or Dellorto twin choke carburettors. £20 · 4-2-1 Mild Steel tubular exhaust manifold – been repaired & needs painting £20 · Bosch competition distributor (non-vacuum) with Lumenition Optronic Sensor £20 · Luminition Ignition Module £40 · Competition Deep V Water Pump Pulley and Crank Pulley for high rpm pair £20 · Std water Pump £10 · Nearly New Geared High Torque Starter Motor (Mint! 1 year old) £60. · Standard 3.0 CIH Starter fits 2.0/2.4 £10 · Lightened Steel flywheel drilled and tapped to take Ford or Opel Covers £20 · Alloy bell-housing with adapter plate to Ford Type 9 box, cable clutch £40. Prices not including postage, Heavy parts will be collection in Nottingham Photos available Cheers Steve Quote Link to comment Share on other sites More sharing options...
mantasrme Posted March 28, 2016 Share Posted March 28, 2016 PM sent re manifolds and pulley. Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted March 28, 2016 Share Posted March 28, 2016 pm sent re flywheel, timing cover, chain tensioner Quote Link to comment Share on other sites More sharing options...
Danny D114BCW Posted March 28, 2016 Share Posted March 28, 2016 PM sent for rocker cover, dizzy and oil pump Quote Link to comment Share on other sites More sharing options...
Aidan Johnston Posted April 3, 2016 Share Posted April 3, 2016 How much does the head weigh? Quote Link to comment Share on other sites More sharing options...
rutts Posted April 3, 2016 Share Posted April 3, 2016 Eighteen kilo so expensive to post tried it. Gave up on it as has to go on a small pallet with most couriers. Quote Link to comment Share on other sites More sharing options...
Aidan Johnston Posted April 3, 2016 Share Posted April 3, 2016 Ok thanks Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted April 3, 2016 Share Posted April 3, 2016 what has sold? Quote Link to comment Share on other sites More sharing options...
Steves Posted April 4, 2016 Author Share Posted April 4, 2016 Hi All Parts not yet sold. Will put on ebay soon. Thought I'd give OMCC community the chance first, Ported Cylinder Head £120 With Ultra big Stainless Steel Valves, Kent OP 264 race camshaft, Kent solid followers, Kent HD valve springs and Bronze valve guides · Nearly New duplex timing chain with crank pulley £20 · Competition Deep V Water Pump Pulley and Crank Pulley (stops belt jumping off at high rpm pair) £20 · Std water Pump £10 · Standard 3.0 CIH Starter fits 2.0/2.4 £10 · Lightened Standard flywheel drilled and tapped to take Ford or Opel Covers £20 Photos available PayPal accepted Quote Link to comment Share on other sites More sharing options...
BEEDZ Posted April 4, 2016 Share Posted April 4, 2016 PM sent Quote Link to comment Share on other sites More sharing options...
shooie811 Posted April 5, 2016 Share Posted April 5, 2016 Pm sent re head Quote Link to comment Share on other sites More sharing options...
Steves Posted April 11, 2016 Author Share Posted April 11, 2016 Hi All Parts not yet sold. Will put on ebay soon. Ported Cylinder Head £120 With Ultra big Stainless Steel Valves, Kent OP 264 race camshaft, Kent solid followers, Kent HD valve springs and Bronze valve guides. · Nearly New duplex timing chain & crank pulley £20 · Competition Deep V Water Pump Pulley and Crank Pulley (stops belt jumping off at high rpm pair) £20 · Std water Pump £10 · Standard 3.0 CIH Starter fits 2.0/2.4 £10 · Lightened Standard flywheel drilled and tapped to take Ford or Opel Covers £20 Cheers Steve Quote Link to comment Share on other sites More sharing options...
Steves Posted April 11, 2016 Author Share Posted April 11, 2016 Head now sold. cheers Steve Quote Link to comment Share on other sites More sharing options...
Steves Posted April 16, 2016 Author Share Posted April 16, 2016 All parts now sold many thanks, Steve 1 Quote Link to comment Share on other sites More sharing options...
