Snowy Posted April 26, 2016 Share Posted April 26, 2016 Can someone show me where on a GTE the wiring for the side repeaters in the wings should come from? I know the way it's wired on my car is wrong. Thanks Quote Link to comment Share on other sites More sharing options...
mantasrme Posted April 26, 2016 Share Posted April 26, 2016 It is scotch blocked (with white blocks) to the indicator wires on the loom just bellow the headlight switch. I can probably show you on a spare loom here tomorrow. 1 Quote Link to comment Share on other sites More sharing options...
mantadoc Posted April 26, 2016 Share Posted April 26, 2016 Red ones on my old exclusive, so I used the same on this one. Connected to the car side of the multiplug the stalk plugs into 1 Quote Link to comment Share on other sites More sharing options...
Snowy Posted April 26, 2016 Author Share Posted April 26, 2016 Thanks guys, someone has removed the wires at some point then linked from under the bonnet by the headlights Thanks Quote Link to comment Share on other sites More sharing options...
mantadoc Posted April 26, 2016 Share Posted April 26, 2016 If you are lucky the slices are still in the wire sleeves from the old scotch locks. IIRC the law changed a while after these wee built so manufacturers could not use that kind of connector. On mine I intend to run the wires through the inner wing above bulkhead / battery tray level. It'll mean two holes and two grommets and an inch or two loop in the engine bay but will remove (some) potential for footwells to leak in (hopefully) 1 Quote Link to comment Share on other sites More sharing options...
