rlf444w Posted October 14, 2016 Share Posted October 14, 2016 on my other post someone mentioned that a member on here has fitted porsche wheels to his manta , i bought a set of revolution rfx from a porsche which came with a conversion kit to fit on 4 x 100mm but when i got them i realised it was for a bolt on rather than studs, it would be nice to speak to a member who has found a way of doing this thanks Quote Link to comment Share on other sites More sharing options...
h0tr0dder_uk Posted October 18, 2016 Share Posted October 18, 2016 you will either need a bolt on conversion (that will probably push your wheels out by an inch or so) or you need to buy some custom front hubs and have the read axles re drilled. It would probably be cheaper to sell the wheels and buy some with the correct bolt pattern. I only converted mine to 5 stud as the wheels I wanted weren't available as 4 stud. Quote Link to comment Share on other sites More sharing options...
