Exclusive Opel Posted October 27, 2016 Share Posted October 27, 2016 Anyone know if the 'C'clips that hold the handbrake cable in the rear back plate are available from a Vauxhall garage? Quote Link to comment Share on other sites More sharing options...
MANTAMAN Posted October 27, 2016 Share Posted October 27, 2016 I have had problems with these clips in the past, the gromits that plug into the backplate can pull through. I found two big bolts that had nuts large enough to go over the end of the handbrake cable. I cut a lengthwise slot in the bolt and cut it just long enough, with two washers i fitted this in place of the gromit. Quote Link to comment Share on other sites More sharing options...
Exclusive Opel Posted October 28, 2016 Author Share Posted October 28, 2016 On 10/27/2016 at 18:32, MANTAMAN said: I have had problems with these clips in the past, the gromits that plug into the backplate can pull through. I found two big bolts that had nuts large enough to go over the end of the handbrake cable. I cut a lengthwise slot in the bolt and cut it just long enough, with two washers i fitted this in place of the gromit. That is a neat solution. You would think they'd supply them with new cables. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted October 28, 2016 Share Posted October 28, 2016 I have a vague memory that the accelerator cable clip from a GT/e fits the handbrake cable to hold the end in place. I might be thinking of the wrong car of course, and i can't help with either clip i'm afraid. But thought i'd mention it in case you have some laying around. Quote Link to comment Share on other sites More sharing options...
andyc Posted October 29, 2016 Share Posted October 29, 2016 Yes they are but ask for the clips for something like a Mk 3 Cavalier, if you get stuck give me a shout and i'll dig the part number out Andy Quote Link to comment Share on other sites More sharing options...
Exclusive Opel Posted October 31, 2016 Author Share Posted October 31, 2016 Thanks for the the replies! Found out they are also the same on the mk4 Astra. Andy, if you could dig out the part number that would be fantastic but no rush. Quote Link to comment Share on other sites More sharing options...
