Kashman Posted March 24, 2018 Share Posted March 24, 2018 Hey guys Some great news Hopefully my manta will be getting delivered to me nxt weekend It's been parked up for 20 years in the owners garage she has a few dings around the body work alil bit of rust on the wing above the passenger front left headlight and odd scratches here and there ...before I put it through a mot I would like to service it can someone advise me the list of things I should do ie what oils to use etc as the plan is I will do what I can and the things that I can't do will go straight to chris in coventry who was recommended to me by Simon Thanks for reading 1 Quote Link to comment Share on other sites More sharing options...
IanMc Posted March 24, 2018 Share Posted March 24, 2018 Nice one, enjoy your Manta! Quote Link to comment Share on other sites More sharing options...
Kashman Posted March 24, 2018 Author Share Posted March 24, 2018 17 minutes ago, IanMc said: Nice one, enjoy your Manta! Cheers I can' wait! Quote Link to comment Share on other sites More sharing options...
wayne ingham Posted March 24, 2018 Share Posted March 24, 2018 Before you start any engine work check that it has oil ,anit freeze in the engine Remove all spark plugs,put a bit of diesel in each clylinder crank engine BY HAND with a spanner on the crank bolt level overnight if the engine turns easy,crank the engine with the key to blow out the xs diesel carry out a compression test,Also check that the oil light goes out If all ok replaced all fluids,filters,spark plugs,check timing Dont forget to replace the brake fluid Quote Link to comment Share on other sites More sharing options...
Kashman Posted March 24, 2018 Author Share Posted March 24, 2018 1 hour ago, wayne ingham said: Before you start any engine work check that it has oil ,anit freeze in the engine Remove all spark plugs,put a bit of diesel in each clylinder crank engine BY HAND with a spanner on the crank bolt level overnight if the engine turns easy,crank the engine with the key to blow out the xs diesel carry out a compression test,Also check that the oil light goes out If all ok replaced all fluids,filters,spark plugs,check timing Dont forget to replace the brake fluid What oil should I use and why? Quote Link to comment Share on other sites More sharing options...
wayne ingham Posted March 24, 2018 Share Posted March 24, 2018 When l did my oil change l used 10 w 40 oil ,as the Manta was only used in the summer time the oil did not have to be 20w 50 Replace the engine oil after about 500 miles as the my be bits of crude in the engine l am correct in thinking that the engine has not run for some time Quote Link to comment Share on other sites More sharing options...
Kashman Posted March 24, 2018 Author Share Posted March 24, 2018 (edited) 26 minutes ago, wayne ingham said: 26 minutes ago, wayne ingham said: When l did my oil change l used 10 w 40 oil ,as the Manta was only used in the summer time the oil did not have to be 20w 50 Replace the engine oil after about 500 miles as the my be bits of crude in the engine l am correct in thinking that the engine has not run for some time Yea we started her with fresh fuel and did the oil change...when i get the car im gona flush the engine then use 20w50 Il get some pictures up when she gets home Edited March 24, 2018 by Kashman 1 Quote Link to comment Share on other sites More sharing options...
Kashman Posted April 7, 2018 Author Share Posted April 7, 2018 Hi guys jus a quick update... It' was a successful day today thanks to the creator of the havens and the earth I have serviced the manta! ..by flushing the engine then changed the oil and oil filter using 1040 semi synthetici replaced the spark plugs using ngk now the rev meter reads around 850 to 900rpm...once warmed up Next on the list is to... deliver the car to chris in coventry soo he can flush the brake sysem. .and replace the ventilation pipes around the petrol tank that are perished and broken... Does the tank need to come out for the ventilation pipes to be fitted ? Do you guys think I should replace the timing chain? Quote Link to comment Share on other sites More sharing options...
Kashman Posted April 18, 2018 Author Share Posted April 18, 2018 I was looking around the neck of the tank and reached to feel the rubber pipes that come off it.. it just crumbled in my hands soo that was the start to see what the tank was like as chris from Coventry said he can get the tank refurbished if the tank had holes etc but thankfully after playing around trying to take the tank off banging my head against the haynes manual I come to find that the tank is in excellent condition so I started the work...pretty proud of myself also I was itching to see if my 16inch 9j borbet wheels fit... so I tried on the rears and they fitted perfect boi she looked good! Quote Link to comment Share on other sites More sharing options...
Kashman Posted May 24, 2018 Author Share Posted May 24, 2018 A quick update JusT passed the mot with no advisories! 2 Quote Link to comment Share on other sites More sharing options...
IanMc Posted May 24, 2018 Share Posted May 24, 2018 Fantastic news - congratulations. Photos please! Quote Link to comment Share on other sites More sharing options...
Kashman Posted May 27, 2018 Author Share Posted May 27, 2018 (edited) Hiya I dnt know how to upload the pics plus iv taken a deposit a few days ago Edited May 27, 2018 by Kashman Quote Link to comment Share on other sites More sharing options...
IanMc Posted May 28, 2018 Share Posted May 28, 2018 1 hour ago, Kashman said: Hiya I dnt know how to upload the pics plus iv taken a deposit a few days ago You are selling it? Quote Link to comment Share on other sites More sharing options...
Kashman Posted May 28, 2018 Author Share Posted May 28, 2018 Yea near enuff sold Quote Link to comment Share on other sites More sharing options...
IanMc Posted May 28, 2018 Share Posted May 28, 2018 That’s a shame, I had assumed that you were doing it up with a view to keeping and enjoying her. Oh well - your car, your choice. Good luck with the sale Quote Link to comment Share on other sites More sharing options...
Kashman Posted May 31, 2018 Author Share Posted May 31, 2018 Iv sold it...with the monies.. im buying my Mrs a car and getting myself another manta very soon possibly a exclusive watch this space ; ) Quote Link to comment Share on other sites More sharing options...
