Snowy Posted July 30, 2018 Share Posted July 30, 2018 Wanted - GTE coupe fuel tank and fuel pump carrier. Thanks Link to comment Share on other sites More sharing options...
Snowy Posted September 4, 2018 Author Share Posted September 4, 2018 Still looking .... Link to comment Share on other sites More sharing options...
paulmanta Posted September 7, 2018 Share Posted September 7, 2018 I have looked and I cant really offer much help, If its any use to you at all I had to make the last couple of fuel pump mounts up from steel plate and angle, I have not seen a good GTE coupe pump mount worth saving on any scrap car for a long time. You used to be able to fix what you have but even that is not an option nowadays, there just not enough left to work to. Do you have anything at all or is this a GTE conversion ? I may have the bracket GM welded to the boot floor crossmember. the one the 3 mounts screw into, triangle shaped thing. I used to cut them off the scrappers for conversions. Link to comment Share on other sites More sharing options...
®evo03 Posted September 7, 2018 Share Posted September 7, 2018 Think i used a cavalier mk3 gsi2000, different shape slightly, but fitted it to the left hand side boot strengthening plate, inside boot to keep it healthy, if it worked in a cav, it will work in a redtop manta! Mounted on three rubber mounts too! Can try a pic tomorrow if any use Link to comment Share on other sites More sharing options...
Danny D114BCW Posted September 8, 2018 Share Posted September 8, 2018 Kevin Abbott has a few tanks for sale Link to comment Share on other sites More sharing options...
yeti132 Posted September 10, 2018 Share Posted September 10, 2018 Yes Kevin Abbott got some for sale on the Facebook site Link to comment Share on other sites More sharing options...
