hoobby Posted August 22, 2018 Share Posted August 22, 2018 (edited) The hose from the intake to air valve has been shortened at some time in the past probably due to splitting at that air valve end but was pulling on the air intake join hence the splitting as far as I can see hasn't gone all the way through.what can I use to repair/strengthen the splitting.also is the hose to the air valve available or something that will fit?. Edited August 22, 2018 by hoobby Aux air hose Quote Link to comment Share on other sites More sharing options...
Danny D114BCW Posted August 22, 2018 Share Posted August 22, 2018 I would just buy a new one or ask on here for a good secondhand one. Not worth repairing as it would be hard to totally seal it. Quote Link to comment Share on other sites More sharing options...
®evo03 Posted August 22, 2018 Share Posted August 22, 2018 Clean it, and use tiger seal, or granville pu flex its about 7quid, but it will work, make sure its clean and dry before Quote Link to comment Share on other sites More sharing options...
Snowy Posted August 22, 2018 Share Posted August 22, 2018 11 hours ago, hoobby said: The hose from the intake to air valve has been shortened at some time in the past probably due to splitting at that air valve end but was pulling on the air intake join hence the splitting as far as I can see hasn't gone all the way through.what can I use to repair/strengthen the splitting.also is the hose to the air valve available or something that will fit?. https://www.edelschmiede.com/shop/navi.php?a=1072&lang=eng Quote Link to comment Share on other sites More sharing options...
BIG STU Posted August 22, 2018 Share Posted August 22, 2018 GET ONE BOUGHT. JOB DONE 👍 Quote Link to comment Share on other sites More sharing options...
hoobby Posted August 23, 2018 Author Share Posted August 23, 2018 Thanks snowy just what I need but for now going to repair as plan to pull the engine out over winter and clean up the engine and bay as it's the only bit of the car that does look 30 years old.also done a repair on the aux air hose.. functional but horrible can't find one any where.first part number 08-26888 then underneath gm 90 080 302 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted August 23, 2018 Share Posted August 23, 2018 I have looked at a few of my spare hoses and they all seem to have the begginings of a split in that area.possibly a weak spot due to the push-in pipe bring a gight fit.the one on my car has the same issue. Was black siliconed 10 years ago and is still holding up well. As for the other hose its only a thinner walled vac hose(12mm ?) im sure someone on here will have one for you or just buy a length of correct bore hose from a factors and place an internal spring on the bend.or a trip to a scrappies should yeild something suitable ftom something ? Surely. Quote Link to comment Share on other sites More sharing options...
Snowy Posted August 23, 2018 Share Posted August 23, 2018 4 hours ago, hoobby said: Thanks snowy just what I need but for now going to repair as plan to pull the engine out over winter and clean up the engine and bay as it's the only bit of the car that does look 30 years old.also done a repair on the aux air hose.. functional but horrible can't find one any where.first part number 08-26888 then underneath gm 90 080 302 If you search through the net you will find plenty of hoses suitable in silicon. If you want a standard rubber hose do what CamInHead has suggested and trawl the scrap yards till you find something suitable. I know my omega has a similar hose used on the cooling system. Quote Link to comment Share on other sites More sharing options...
hoobby Posted August 23, 2018 Author Share Posted August 23, 2018 The hose has two different id's 11mm and 13mm what genius thought of that sure I can sort something out thanks for all the help,new master cylinder arrived today and 12mm fuel hose which is actually 8mm Quote Link to comment Share on other sites More sharing options...
