Limited slip diffs
clivecoupe
I had one fitted to my cavalier with Xe on tb's it was good for donuts and did lock up well when drag starting etc but was not so good for lanes I waited over 12months and manage to find a zf plate diff swapped it over different car to drive altogether with the advantage of diff locking on and off the throttle if u select the right ramp angles makes it a lot easier to throw the car from one bend to the next in other words if I gave it a flick to set up up for the bend with the black line it would only start to slide when applied powe was as the zf would come out straight away and pulled the car back straight nicely under full throttle     Get a plate diff I think the grippers are of a similar design to the zf black line did wat it said but if u drive hard u want a plate diff
Hi. Yes I did but I'm not sure if they meant me or not. I bought quite a bit of stuff off them for my Mantas, Ascona and Escort and they knew where I was from. Not been there for a couple of years now but when I dig my Escort back out I'll be up there again I'm sure.
Luke.
  • 10 months later...
