611 Posted January 7, 2019 Share Posted January 7, 2019 Anyone know where you can get the track rod end locking nuts for the A series or the size so i can track some down? As im unable to locate the safe place i put mine in 🙂  I found these but im not sure if the size is correct for the A? https://www.roughtrax4x4.com/track-rod-end-lock-nut.html?gclid=EAIaIQobChMIxYGylr3b3wIVw4TVCh1J-wxvEAYYASABEgKkkfD_BwE  Thanks Andy Link to comment Share on other sites More sharing options...
®evo03 Posted January 7, 2019 Share Posted January 7, 2019 Dont know what an A has, if same a B, they are castle nuts, locked with a split pin.  Link to comment Share on other sites More sharing options...
Paul Barrett Posted January 7, 2019 Share Posted January 7, 2019 They are slim nut. Link to comment Share on other sites More sharing options...
611 Posted January 7, 2019 Author Share Posted January 7, 2019 54 minutes ago, Paul Barrett said: They are slim nut. Yep, slim nut . The ones that wind up and lock the track rod where it comes out of the steering rack. Think i might have found one, but need to take the track rod out to see if it is the right one. If it is im just after the one! 1 hour ago, ®evo03 said: Dont know what an A has, if same a B, they are castle nuts, locked with a split pin.  Not sure on the B, the A has the castle nut on the ball joint but a slim nut to lock the trackrod arm after you have adjusted it out from the rack. Link to comment Share on other sites More sharing options...
®evo03 Posted January 7, 2019 Share Posted January 7, 2019 Ah, got ya Link to comment Share on other sites More sharing options...
H-400 Posted January 8, 2019 Share Posted January 8, 2019 This pic comes from a Manta-A technical manual: Link to comment Share on other sites More sharing options...
611 Posted January 8, 2019 Author Share Posted January 8, 2019 4 hours ago, H-400 said: This pic comes from a Manta-A technical manual: That shows the one 🙂 Its the one between the tie rod end and the end of the steering rack universal joint. I dont suppose you know the size or part number? Andy Link to comment Share on other sites More sharing options...
H-400 Posted January 8, 2019 Share Posted January 8, 2019 I think you mean the one in the red cirkel: On a "B" (other design but compareble) it is a 14mm thread, if so we are yet sure what nut it is. Than we can dig further, so let us know. Link to comment Share on other sites More sharing options...
Mickfrad Posted January 8, 2019 Share Posted January 8, 2019 (edited) Plenty of half thickness nuts available on eBay https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F121876667036 Also different threads available https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F183606795280 I have a b series rack in the garage somewhere I can check the size if you need me too. Just went and checked m14 X 1.5 pitch on the b if it's the same Edited January 8, 2019 by Mickfrad Link to comment Share on other sites More sharing options...
611 Posted January 8, 2019 Author Share Posted January 8, 2019 4 hours ago, H-400 said: I think you mean the one in the red cirkel: On a "B" (other design but compareble) it is a 14mm thread, if so we are yet sure what nut it is. Than we can dig further, so let us know. That's the one 🙂 I have one which looks like it should be right so i will give it a measure and see if its the same size and then i should be able to get a couple of new ones. Thanks for all the help. 1 hour ago, Mickfrad said: Plenty of half thickness nuts available on eBay https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F121876667036 Also different threads available https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F183606795280 I have a b series rack in the garage somewhere I can check the size if you need me too. Just went and checked m14 X 1.5 pitch on the b if it's the same Amazing, thanks for all the help, looks like it its the same on the A but will check the one i have to make sure and order a couple, thanks for the links 🙂 Link to comment Share on other sites More sharing options...
611 Posted January 15, 2019 Author Share Posted January 15, 2019 Just thought i would update this thread in case anyone stumbles across it, as i hate it when you find a thread and no one puts on it how it was resolved! I found these and they fit perfect on the A series. https://www.brickwerks.co.uk/half-nut-m14-x1-5-bzp.html  Andy  2 Link to comment Share on other sites More sharing options...
Paul Barrett Posted January 15, 2019 Share Posted January 15, 2019 Well done 1 Link to comment Share on other sites More sharing options...
