1200bandit Posted August 20, 2019 Share Posted August 20, 2019 I am after a thing that screws into the top hose housing on a 2.0 Sri engine l think it is a 8 mm tread looks something like what’s in the photo can be straight out Link to comment Share on other sites More sharing options...
IanMc Posted August 20, 2019 Share Posted August 20, 2019 If you get stuck, I suppose you could improvise by using something like these two items - one inside the other with some PTFE tape of course... https://www.ebay.co.uk/itm/10Pcs-M8-Full-Threaded-Lamp-Nipple-Pass-Through-Pipe-Connector-30mm-Length/362281672798?epid=17009303513&hash=item5459aba05e:g:DuoAAOSw3hFdVIr4 https://www.ebay.co.uk/itm/A2-STAINLESS-STEEL-ALL-THREAD-SLEEVE-ROD-BAR-STUD-ROUND-CONNECTOR-TUBE-LONG-NUTS/111846278490?hash=item1a0a8ec55a:m:mbLe00FLh6nrc_FwQYlqz-Q Link to comment Share on other sites More sharing options...
1200bandit Posted August 20, 2019 Author Share Posted August 20, 2019 Had a look on eBay and found one that may fit ,but l will have to remove the blank Cheers lan for the heads up Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 20, 2019 Share Posted August 20, 2019 Looks like 1/4 bsp, put it next to a ruler or tape measure. Link to comment Share on other sites More sharing options...
