P stamped flywheel bolt
ANDY ABBOTT
That "P"bolt has got following partnr:  6 16 281
                                                  GM partnr: 90299277
If you want I can check it on this side of the channel, don't try one of another CIH engine, the thread is different.
                                                  GM partnr: 90299277
Thanks Herman. I'll see if any dealers have a stock
It was some time ago I replaced a flywheel of a CIH, I noticed 1 hole in the flywheel was also smaller than the rest so the "P bolt" fits tighter.
If you are going to check the stock of your local Opel dealer: They can look also in all the stock of every other Opel dealer, hope you are lucky. Will visit our dealer when I drive back from the barracks.
  • Thanks 1
17 minutes ago, 1200bandit said:
Is the tread a fine tread ,as Renault,Nissan flywheel bolts are a fine tread
Thanks Wayne. But after the previous bolts snapping I don't want to take any chances. Want it like for like. So I knows it's correct 👍
