Jessopia74 Posted March 24, 2021 Author Share Posted March 24, 2021 Just now, Trooker said: Bummer that the block is cracked, why does it need to be an early one? Nostalgia really, but the earlier blocks are thicker castings too. Otherwise I could use the 2.4 block I guess, but only want to build this engine once.ย 1 Quote Link to comment Share on other sites More sharing options...
H-400 Posted March 24, 2021 Share Posted March 24, 2021 Sorry to read about your cracked block. But looks like you found out the solution for the headbolts. About the 2.4: The older CIH blocks are a better quality of cast iron. But I bought in 1993 a brand new original naked 2.4 (with crankshaft, rods & pistons) and made the block complete with 2.0 CIH parts. Had to rebuild the engine last year cause my cilinders were 0,25mm oval. I bored & honed the engine to the next size cause it took me more than 28ย years to wear it out, think I wont do that much km's the next years.ย 2 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted March 24, 2021 Author Share Posted March 24, 2021 (edited) 13 minutes ago, H-400 said: Sorry to read about your cracked block. But looks like you found out the solution for the headbolts. About the 2.4: The older CIH blocks are a better quality of cast iron. But I bought in 1993 a brand new original naked 2.4 (with crankshaft, rods & pistons) and made the block complete with 2.0 CIH parts. Had to rebuild the engine last year cause my cilinders were 0,25mm oval. I bored & honed the engine to the next size cause it took me more than 28ย years to wear it out, think I wont do that much km's the next years.ย Thanks Herman. The bores in this 2.4 are excellent. We are going to pull the pistons tomorrow to check the full wear, but initial checks are positive. So plan B is an option, but would prefer to put the 2.4 into an early 1.9ย block with a fresh stdย bore. Also hope to visit the machine shop too, see how much of a crackpot they think I am when I explain the plan ๐ Edited March 24, 2021 by Jessopia74 3 1 Quote Link to comment Share on other sites More sharing options...
moodoo Posted March 24, 2021 Share Posted March 24, 2021 I knew Iย had read somewhere about the early 1.9s being thicker castings, or is it just the quality of the material? Early ones also definitely did have forged rods, I have a set. Thereโs a couple of good pics on opelgt to show the differences. Good luck atย the machine shop! 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted March 24, 2021 Author Share Posted March 24, 2021 8 minutes ago, moodoo said: I knew Iย had read somewhere about the early 1.9s being thicker castings, or is it just the quality of the material? Early ones also definitely did have forged rods, I have a set. Thereโs a couple of good pics on opelgt to show the differences. Good luck atย the machine shop! Yes, pre 74 I think had forged internals, but obviously I am not after the rods etc, although I have a set now.ย Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted March 25, 2021 Author Share Posted March 25, 2021 Good day today, sun shining and things going to plan. Took head down this morning along with my iPad to see theย Engineering shop, and theyย said yes, no problem ๐ย They specialise in cast Alu and SS welding pipwork and have a bit if a hobby sideline with stuff they are interested in. So they used to doing cast Alu welding that usย none porous for industrial chem sites, so good enough for a car head !ย They can Cut, build up weldsย and machine down in thier shop;ย best of-allย they are within a fewย of miles of my house -ย happy days ๐ฅณ So back to workshop and spent rest of today completely stripping the head bare.ย Also extracted the snapped studs in the 2.4 head, both came out easy as hot knife through butter. My luck is in today! Maybe I shouldย haveย out some cash on lotto ๐ค Pics attached with a few markings. Pretty much nailed the procedure now and it's all starting to make a bit more sense too. Dropping head off tomorrow, first thing they will do is get it chopped to see what's what. ย Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 5 Quote Link to comment Share on other sites More sharing options...
H-400 Posted March 26, 2021 Share Posted March 26, 2021 Maybe you should give the CIH block with the head into the shop.ย Do those metal guiding pins fit in the 24V head? 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted March 26, 2021 Author Share Posted March 26, 2021 29 minutes ago, H-400 said: Maybe you should give the CIH block with the head into the shop.ย Do those metal guiding pins fit in the 24V head? Not at the moment. The block does work anyway, as it needs a new bolt hole drilling for front left stud. I was thinking about the location pins, but they are different size depending what block I use.ย ย Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted March 29, 2021 Author Share Posted March 29, 2021 Head gasket with correct bolt hole for the 16v head. Fair play for BurtonPower, they sent it between to planks of woood wrapped in bloody thick card. No way this was getting bent in transit ๐ช๐ย You can see in pic1 the slotted 1st bolt hole. Correct Part # (also in pics) Cometic ย C4512-051 (https://www.cometic.com/products/C4512-056) Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 4 Quote Link to comment Share on other sites More sharing options...
Buz Posted March 29, 2021 Share Posted March 29, 2021 One of , as I see it , the many positives of this route is the crossflow element which means no hassle with the brake servo. What plans have you got for the manifolds. Iโm hoping to have a bash at fabricating some to try and keep costs down which is one of , as i see it , the many negatives of this route ๐ 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted March 29, 2021 Author Share Posted March 29, 2021 45 minutes ago, Buz said: One of , as I see it , the many positives of this route is the crossflow element which means no hassle with the brake servo. What plans have you got for the manifolds. Iโm hoping to have a bash at fabricating some to try and keep costs down which is one of , as i see it , the many negatives of this route ๐ Not really thought to much about exhaust yet, but they use the injector holder a separate part, or go for some Twin DCOE manifolds that seem to be available and then use Jenvey throttle bodies.ย Exhaust wise, I suspect bespoke manifold woukd be cheaper than the โฌ1200 for the ones I have seen available.ย Quote Link to comment Share on other sites More sharing options...
Buz Posted March 31, 2021 Share Posted March 31, 2021 Had a look at the engine yesterday and hadnโt noticed the short injector manifolds/ housing. I guess itโs an option. ย I wonder how the distance from the injection point to inlet would affect performance. I guess with injection itโs less fussyย than carbs . Still planย to go throttle bodies though as this opens up possibilities. ย Also hoping to make a jig from the 3 litre for drilling the chain guide.ย https://translate.google.com/translate?sl=auto&tl=en&u=http://www.mantawelt.de/cih16v-projectone-08.htm ย ย 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted March 31, 2021 Author Share Posted March 31, 2021 1 hour ago, Buz said: Had a look at the engine yesterday and hadnโt noticed the short injector manifolds/ housing. I guess itโs an option. ย I wonder how the distance from the injection point to inlet would affect performance. I guess with injection itโs less fussyย than carbs . Still planย to go throttle bodies though as this opens up possibilities. ย Also hoping to make a jig from the 3 litre for drilling the chain guide.ย https://translate.google.com/translate?sl=auto&tl=en&u=http://www.mantawelt.de/cih16v-projectone-08.htm ย ย There was a drawing kicking about on the FB group. I asked if anyone had received it and coukd they share - nada ๐คฆ๐ปโโ๏ธ the injectors are positioned so they hit the back of the valves. Not sure if it's less efficient, however the A400 engine injectors are a little further back but still aim at same point from what I can see. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 11, 2021 Author Share Posted April 11, 2021 (edited) I happened upon something last week, was delivered back yesterday - managed to pop down to the garage to see it running extremely sweet. Sounds lovely, 70k auto engine grandad been pottering about in it, then was parked up. Obviously I only want certain bits off the engine ๐ฌ๐ Project images are available to Club Members Only, Click to become an OMOC Member. Edited April 11, 2021 by Jessopia74 2 Quote Link to comment Share on other sites More sharing options...
Trooker Posted April 11, 2021 Share Posted April 11, 2021 Startingย a new collection?ย Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 11, 2021 Author Share Posted April 11, 2021 (edited) 29 minutes ago, Trooker said: Startingย a new collection?ย Only for the 16v head conversion mate, although maybe park it in the corner of the yard and hope no one hassles me about it for a few years ๐ Edited April 11, 2021 by Jessopia74 Quote Link to comment Share on other sites More sharing options...
Trooker Posted April 11, 2021 Share Posted April 11, 2021 1 hour ago, Jessopia74 said: Only for the 16v head conversion mate, although maybe park it in the corner of the yard and hope no one hassles me about it for a few years ๐ ๐ย For some reason I thought you already had the head etc was wondering if you are going into production.ย ๐ 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 11, 2021 Author Share Posted April 11, 2021 2 minutes ago, Trooker said: ๐ For some reason I thought you already had the head etc was wondering if you are going into production.ย ๐ No your right I do have the head, but I was missing a few other bits and happened on the who,e thing - stupid car attached ๐คฆ๐ปโโ๏ธ Although doing 2 at the same time is an option now ๐ค๐ ย was thinking more of a spare. You started something now mate......๐ค 1 Quote Link to comment Share on other sites More sharing options...
Buz Posted April 11, 2021 Share Posted April 11, 2021 Aah. So it was you that bought it and out bid me ๐๐๐ Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 11, 2021 Author Share Posted April 11, 2021 Just now, Buz said: Aah. So it was you that bought it and out bid me ๐๐๐ Did you want the car or just the Engine Buzz? Quote Link to comment Share on other sites More sharing options...
Buz Posted April 11, 2021 Share Posted April 11, 2021 My wife thanks you and has added you to the Christmas card list ๐ Same as you Jess , just the engine really, I want to do two heads at the same time. I think you ought to do the right thing by the car and repair it , it only looks a weekend job ๐ค๐คช Could I be cheeky and ask a ball park figure on how much they charged for getting it back to you . ย It was a long way south ๐ฑ 2 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 11, 2021 Author Share Posted April 11, 2021 8 minutes ago, Buz said: My wife thanks you and has added you to the Christmas card list ๐ Same as you Jess , just the engine really, I want to do two heads at the same time. I think you ought to do the right thing by the car and repair it , it only looks a weekend job ๐ค๐คช Might take a look when I have time off to get it up on the ramp, but probably better examples out there to save from the external bits I have seen Quote Link to comment Share on other sites More sharing options...
Buz Posted April 11, 2021 Share Posted April 11, 2021 It looked rough. To be far if I had won the car I would have sorted you out with the guides and the cam sprockets as I know you were looking for them . Then I would have broke the car and sold parts on the senator group. Iโm wondering about the pistons in the C30se as Iโm sure they are 95mm, but no idea on heights and skirt lengths and even whether itโs worth reusing them even if they are in good condition. Probably best to go down the omega route. Have you seen there is a 1.9 block on eBay at the moment , if you are still looking for one ?ย Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 11, 2021 Author Share Posted April 11, 2021 13 minutes ago, Buz said: It looked rough. To be far if I had won the car I would have sorted you out with the guides and the cam sprockets as I know you were looking for them . Then I would have broke the car and sold parts on the senator group. Iโm wondering about the pistons in the C30se as Iโm sure they are 95mm, but no idea on heights and skirt lengths and even whether itโs worth reusing them even if they are in good condition. Probably best to go down the omega route. Have you seen there is a 1.9 block on eBay at the moment , if you are still looking for one ?ย Doh if only you had of said ๐ค Pistons areย No good for a 2,4 crank, nothing really from bottom end of any use apart from sprocket. I just had a message about sone other bits, so might not need to break this at all. I know gearbox is fubar and it has no brakes either, but engine is sweet. Nothing will be decided anyway for a week or two due to work. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted July 13, 2021 Author Share Posted July 13, 2021 So the 24v engine has gone to a good home a chap who lives not too far was in touch that has one in a Manta that is fubar, so he has taken my lump less a couple of bits to get his running again ๐ Had a few days this week on the 400 finally!!! Fabricated a prop-shaft to be used as template that will be sent off as a pattern for specialists to build me one to specification. 2 piece prop. Fitted the Commodire GSE hubs to convert over to 5stud, and swapped the rear axle over too.ย Managed to loan some BMW msport 18" wheels from the new bodyshop that's opened next to my unit. Only fitted as I needed 5stufpd wheels to push it about, but it supprised me how good the 18" rims look on the car and it can carry them off ๐ Still tons to do, but have made some modification tests to front subframe and steering rack height I needed to do, so feel like I am making progress again. It's been too long since I have been able to work on one of my cars, so it's all positive ๐ป ย ย Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. 3 Quote Link to comment Share on other sites More sharing options...
