Wardmar Posted April 24, 2020 Share Posted April 24, 2020 I'm using a 1.9 ascona engine that I want to convert to electronic ignition so need the correct distributor. I'm open to advice on what I need. Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 24, 2020 Share Posted April 24, 2020 One from Gte, with its amplifier(attached to coil) Link to comment Share on other sites More sharing options...
Wardmar Posted April 25, 2020 Author Share Posted April 25, 2020 9 hours ago, Jessopia74 said: One from Gte, with its amplifier(attached to coil) Thanks. Now I just need to find one. 🙂 Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 25, 2020 Share Posted April 25, 2020 1 hour ago, Wardmar said: Thanks. Now I just need to find one. 🙂 There is another alternative, only used it years ago that does not need a crank sensor and is fairly straight forward replacement. I did fir one to my first 1.9 SRB Manta some years ago and it was simple but solid performer. And I am sure they have improved since then too. Optronic kit replaces the points with an optical sensor and a plastic blade fits over the square https://www.demon-tweeks.com/uk/brand/lumenition/ 1 Link to comment Share on other sites More sharing options...
IanMc Posted April 25, 2020 Share Posted April 25, 2020 I have one of these kits fitted to my Mk1 Cavalier Coupe 2.0: http://www.accuspark.co.uk/car_search.html No complaints so far... 1 1 Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 25, 2020 Share Posted April 25, 2020 34 minutes ago, IanMc said: I have one of these kits fitted to my Mk1 Cavalier Coupe 2.0: http://www.accuspark.co.uk/car_search.html No complaints so far... That’s a lot cheaper solution, and presume easier to fit. Link to comment Share on other sites More sharing options...
IanMc Posted April 25, 2020 Share Posted April 25, 2020 3 minutes ago, Jessopia74 said: That’s a lot cheaper solution, and presume easier to fit. Only takes five minutes mate 1 Link to comment Share on other sites More sharing options...
Wardmar Posted April 25, 2020 Author Share Posted April 25, 2020 I might end up using one of these options, I was just hoping to use the original parts if I could find them. Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 25, 2020 Share Posted April 25, 2020 The GTE distributors use similar to the mechanical one you have now + an electronic upgrade. Infact, I would suggest that your better keeping the original distributor and use a ‘points replacement’ as it can always be reverted back to item if you wish to keep it looking that way. Link to comment Share on other sites More sharing options...
MrCarlos Posted April 26, 2020 Share Posted April 26, 2020 I can do a gte dizzy, coil, module and loom for £60 plus postage - everything you need 🙂 Link to comment Share on other sites More sharing options...
