611 Posted May 3, 2020 Share Posted May 3, 2020 Hi All A bit of a long shot, but under the A series dash there is a heater piper that goes up to the centre vents and its nice and flat to fit up past the heater box etc.. and im looking for one if anyone has got a spare? Thanks Andy Link to comment Share on other sites More sharing options...
MrCarlos Posted May 4, 2020 Share Posted May 4, 2020 I probably have one - do you have a pic of what you need ? Link to comment Share on other sites More sharing options...
611 Posted May 4, 2020 Author Share Posted May 4, 2020 3 hours ago, MrCarlos said: I probably have one - do you have a pic of what you need ? Sorry, i dont, as the one i have is up under the dash, i need another one as i have a modified pedal set and the standard round pipe wont fit back past it from the outer vents. i can try and see if i an get any sort of a pic from under the dash tomorrow. Andy Link to comment Share on other sites More sharing options...
Shug Posted May 4, 2020 Share Posted May 4, 2020 You can buy flexible pipe the right diameter. I used it to replace missing driver side duct. Can route it anyway you want then. Link to comment Share on other sites More sharing options...
611 Posted May 5, 2020 Author Share Posted May 5, 2020 19 hours ago, Shug said: You can buy flexible pipe the right diameter. I used it to replace missing driver side duct. Can route it anyway you want then. Thanks, Shug Its the flat pipe that i need. Im all good with the normal hose. This part connects the normal hose either end but is nice and flat so it sits behind the dash snugly 🙂 Link to comment Share on other sites More sharing options...
