Jessopia74 Posted December 26, 2020 Share Posted December 26, 2020 8 hours ago, Exclusive Opel said: I have one of those kits but the full one. Great bit of kit. Only thing to watch is when using the lever, it's sitting square on the round bar otherwise it can skid off. Used one on an Astra 16v head and made the job so much easier as the valves/springs are deeply recessed. Work with head in situe? Quote Link to comment Share on other sites More sharing options...
Limeysore Posted December 26, 2020 Share Posted December 26, 2020 Herman, first off Mery Christmas to you and yours. On the pistons for the 400, if you can get me the specs and dimensions for the pistons I'll check to see it there is anyhing comparable available this side of the Atlantic. One of our local Opel guru's (John Warga) is a CNC machine wizzard and has modified pistons to work in his 2.4 CIH build, I’ll talk to John and see if he has any ideas. I’ll send you some pictures of John’s work via e-mail. Chris 4 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted December 26, 2020 Share Posted December 26, 2020 1 hour ago, Limeysore said: Herman, first off Mery Christmas to you and yours. On the pistons for the 400, if you can get me the specs and dimensions for the pistons I'll check to see it there is anyhing comparable available this side of the Atlantic. One of our local Opel guru's (John Warga) is a CNC machine wizzard and has modified pistons to work in his 2.4 CIH build, I’ll talk to John and see if he has any ideas. I’ll send you some pictures of John’s work via e-mail. Chris I would take a set of those if the price is reasonable too 🍻 Quote Link to comment Share on other sites More sharing options...
Exclusive Opel Posted December 26, 2020 Share Posted December 26, 2020 3 hours ago, Jessopia74 said: Work with head in situe? Yes! Obviously need the rope trick or compressed air to hold valve. I have the original standard CIH valve compressor - bit of bent metal with a couple of holes! I could always do a quick drawing if anyone wants to make one. 1 Quote Link to comment Share on other sites More sharing options...
IanMc Posted December 27, 2020 Share Posted December 27, 2020 Great stuff Herman - good luck with this project. As always, your attention to detail inspires all of us! 14 hours ago, Exclusive Opel said: I have the original standard CIH valve compressor - bit of bent metal with a couple of holes! I could always do a quick drawing if anyone wants to make one. Yes please! Quote Link to comment Share on other sites More sharing options...
H-400 Posted December 27, 2020 Author Share Posted December 27, 2020 Thanks for the info & offers. @Chris: Pictures of your émail show nice work, thanks. The tool I made myself looks like this: Project images are available to Club Members Only, Click to become an OMOC Member. easy to use and cheap to make 2 Quote Link to comment Share on other sites More sharing options...
Exclusive Opel Posted December 29, 2020 Share Posted December 29, 2020 On 27/12/2020 at 12:01, IanMc said: Yes please! No problem, I'll sort it out asap. Quote Link to comment Share on other sites More sharing options...
Exclusive Opel Posted December 29, 2020 Share Posted December 29, 2020 Here you go! Hopefully it's all makes sense! If I've missed anything off then let me know. Project images are available to Club Members Only, Click to become an OMOC Member.Project images are available to Club Members Only, Click to become an OMOC Member.Project images are available to Club Members Only, Click to become an OMOC Member.Project images are available to Club Members Only, Click to become an OMOC Member. 4 2 Quote Link to comment Share on other sites More sharing options...
IanMc Posted December 29, 2020 Share Posted December 29, 2020 41 minutes ago, Exclusive Opel said: Here you go! Hopefully it's all makes sense! If I've missed anything off then let me know. You are a Superstar - sincere thanks! Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted December 31, 2020 Share Posted December 31, 2020 This eBay valve compressor doesn’t look as strong or the same quality as the ones above. But may be of use if not able to make one yourself. https://www.ebay.co.uk/itm/163711140274 Quote Link to comment Share on other sites More sharing options...
H-400 Posted January 6, 2021 Author Share Posted January 6, 2021 Making some progress, but slowely. All the valves are out and measured the base of the stemseals. Looks I found a solution so gonna order a small batch of them to test. The new tool works fine, but I drilled on both sides a hole in the metal rod to fit a safetypin so it can't jump out of the brackets while opening the valve: Project images are available to Club Members Only, Click to become an OMOC Member. Yes I used two sockets as spacers😁. The chain-guides look total different, the tensioner is fitted in the head: Project images are available to Club Members Only, Click to become an OMOC Member. Timing cover house looks the same, the location of the CIH tensioner is plugged of but the long tensioner-guide pivots on the same pin as a CIH engine: Project images are available to Club Members Only, Click to become an OMOC Member. Grts, Herman 1 1 Quote Link to comment Share on other sites More sharing options...
611 Posted January 6, 2021 Share Posted January 6, 2021 Nice work Herman At least you are keeping nice and busy in these times when we cant go very far. I did start removing my heater box to swap it with a better one just before Christmas when the weather was quite nice but its been far too cold to finish it. Hoping it warms up next week here as i have plenty of time for the next couple of months -) 3 Quote Link to comment Share on other sites More sharing options...
H-400 Posted January 6, 2021 Author Share Posted January 6, 2021 Hi Andy, well I'm searching for parts behind my PC and doing some work on the "400" and keep myself on the programm of the physio for my knee. Two times / week 3 hours sweating on his machines and a few days a week at home to get the muscles back alive of my right leg so I hope I can run again this spring... Yes I'm busy! Hope the Corona-situation in the UK will get better soon, noticed the vaccination is going well on your side but in Belgium the vaccination is just started symbolic. Stay healthy. 1 Quote Link to comment Share on other sites More sharing options...
611 Posted January 6, 2021 Share Posted January 6, 2021 1 hour ago, H-400 said: Hi Andy, well I'm searching for parts behind my PC and doing some work on the "400" and keep myself on the programm of the physio for my knee. Two times / week 3 hours sweating on his machines and a few days a week at home to get the muscles back alive of my right leg so I hope I can run again this spring... Yes I'm busy! Hope the Corona-situation in the UK will get better soon, noticed the vaccination is going well on your side but in Belgium the vaccination is just started symbolic. Stay healthy. Hey Herman That sounds like a lot of hard work for the Physio, i hope it all goes in the right direction and you are ready for that spring run 🙂 I had planned for a lockdown so i have a few projects planned to keep me busy in these winter months, i just need a bit of warmer weather to get on with the car. The vaccination does seem to be stepping up over here but there is a long way to go. Keep the pictures coming of the engine build as its quite interesting to see the difference in the engine. 1 Quote Link to comment Share on other sites More sharing options...
H-400 Posted January 11, 2021 Author Share Posted January 11, 2021 Tried to contact "Omega-Pistons". Last week (Wednesday) I mailed them but no answer. Disappointed, I am used to get a confermation after a message, been too long in the army... Today I filled in an automatic contact question form on their website. Noticed the head gasket needs to be special for a "400" engine. The head has got other water channals, even the shortened 24V head is different. Need also new gaskets for the cam-covers and the tensioner cover. Can order those gaskets @ Risse in Germany. Will take some pics, makes everything easier. Am yet trying to go up backwards on the stairs. After a meniscusoperation painfull but important. When I come home from the pub the wife thinks I'm going down to the loo... Got some time untill the lockdown is ended. Stay healthy, Herman 2 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 11, 2021 Share Posted January 11, 2021 Think the C19 situation has been an excuse for all companies to dumb down the service levels, sadly. Hopefully they will get back to you after a few days. Good info on the Head Gaskets 👍 Quote Link to comment Share on other sites More sharing options...
H-400 Posted January 16, 2021 Author Share Posted January 16, 2021 Omega Pistons mailed me last week. They wrote they had no stock of "400" pistons cause it is made by order. So I mailed to them I want to order a set of pistons, no problem to wait. The guy I had this conversation "Alex" was helpfull and he recognized some names I knew that ordered "400" pistons at Omega. Problem is you need to order 20 pistons and they have to be the same diameter and compression. Am yet waiting for an answer from Holland if they can make a set, think I'v got to inform my insurance I won't drive the "400" for some months... Found out Wiseco makes pistons that fit in the 2.4CIH with cut off 24V head so maybe that can be a solution. Done not a lot on my engine, but you all love to see pictures. The first picture is one of the pistons. The left one is the 2.4CIH , the other is the "400" one. Production OEM one and as you all can see not a big difference. Both pistons have the same pin and while a GSI-GT/E 2 liter CIH needs to warm up and pressed out those pins are floating. Both pins have the same ofset so maybe I can use CIH high compression pistons to mill them... Project images are available to Club Members Only, Click to become an OMOC Member. This is a pic of the 16V head, you can all see the water channels are almost identical as the CIH cast iron head: Project images are available to Club Members Only, Click to become an OMOC Member. And a pic of the same head with the original head gasket, one side (left side of the car) the water channels are blocked and the other side we can see some holes in the gasket: Project images are available to Club Members Only, Click to become an OMOC Member. This is a picture of two head gaskets. The bottom one is the original "400" one and the top one is CIH, looks the CIH gasket blocks the water channels on the other side..: Project images are available to Club Members Only, Click to become an OMOC Member. And when I look to the web shop of Risse motorsport their "400" head gasket has on both sides openings for the water channels: Project images are available to Club Members Only, Click to become an OMOC Member. Hmm, got to think this over... Another pic of the chain guides: Project images are available to Club Members Only, Click to become an OMOC Member. Have a nice weekend, stay healthy Herman 4 1 Quote Link to comment Share on other sites More sharing options...
611 Posted January 16, 2021 Share Posted January 16, 2021 We all love engine pictures Herman 🙂 Its quite interesting to see the difference between the 2.4 and 400 parts. If you dont have any luck with the pistons it might be worth signing up to the Opel GT forum to see if they have any sources for pistons as it might be that if you could the broken piston to someone that they could make a set as they guys over there seems to talk quite a bit about having sets made? And they put 2 extra holes in the 2.4 gasket to help cooling around pistons 2 and 3 so a similar idea to the 400. Andy Project images are available to Club Members Only, Click to become an OMOC Member. 1 Quote Link to comment Share on other sites More sharing options...
Limeysore Posted January 17, 2021 Share Posted January 17, 2021 Herman, if you can get me the dimensions of the piston you require I’ll see what might be available over here. Most of the 2.4 engine guys over here use Chevrolet 305ci Hypereutectic pistons in their builds, they do need some modifications but nothing overly drastic. 2 Quote Link to comment Share on other sites More sharing options...
H-400 Posted January 17, 2021 Author Share Posted January 17, 2021 Thanks for all the info, @Chris: I mailed some firms this weekend, hope to get some answers after the weekend. Had a mail from a friend (also a "400" owner) with a link that looks promising. 1 Quote Link to comment Share on other sites More sharing options...
H-400 Posted January 18, 2021 Author Share Posted January 18, 2021 Looks like I found a set of pistons, Omega ones 95,50 compression 11/1. And found out the original cranck and conrod bearings of a "400" have the same partnr. as a GT/E. So the original cranckshaft of a "400" is nitrated and can deal with the most power they could make in those days, as mentioned in the original Opel specifications. So the GT/E has got pretty good bearings... 6 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 18, 2021 Share Posted January 18, 2021 1 hour ago, H-400 said: Looks like I found a set of pistons, Omega ones 95,50 compression 11/1. And found out the original cranck and conrod bearings of a "400" have the same partnr. as a GT/E. So the original cranckshaft of a "400" is nitrated and can deal with the most power they could make in those days, as mentioned in the original Opel specifications. So the GT/E has got pretty good bearings... good to hear mate. Quote Link to comment Share on other sites More sharing options...
H-400 Posted March 6, 2021 Author Share Posted March 6, 2021 After two months there is some news to tell. The set of pistons was not complete cause they lend one out to copy them. And thanks to covid we are not allowed to cross the German border but this week I had a mail from Risse Motorsport they have a set of pistons for me. They are going to send them to me, insured,together wit some other parts. So I'm motivated to start again. My wife came home from the athletic club but she couldn't shower, err Honey there something in the bath-tub... I needed hot water to degrease something: Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. Ofcourse I cleaned up all the mess😄. And the firm that makes aluminium profiles contacted me also, the parts for my little truck are approved for production. Hold your horses, not all together! 1 6 Quote Link to comment Share on other sites More sharing options...
IanMc Posted March 6, 2021 Share Posted March 6, 2021 Great news on the parts Herman - Onwards! 1 Quote Link to comment Share on other sites More sharing options...
H-400 Posted March 6, 2021 Author Share Posted March 6, 2021 Thanks Ian, cleaned also eight of the 16 valves. 2 Quote Link to comment Share on other sites More sharing options...
