moodoo Posted January 12, 2021 Share Posted January 12, 2021 Folks, Been away from the club for a while, but am able to do some work on my A-series again now. First on the list is to replace the bearings in the steering column. I have both upper and lower bearings (I think). Can anyone confirm if the below is the right bearing for the bottom of the A-series column? It seems to have a rectangular 'thing' sticking out of the side, but I can't see where that would locate in the column outer? My column outer seems to have a hole for a round 'thing'? Also in the bag with the bearing were the 2 blue items. One looks like a sort of flat spring maybe, the other smaller one I have no idea. Anyone know where they go? Thanks! Fin Quote Link to comment Share on other sites More sharing options...
611 Posted January 12, 2021 Share Posted January 12, 2021 Hey Fin I will reply to your message in a bit. The bearing is the lower one in the engine bay, think they were from the B series as the A was one that had felt and not ball bearings. I replaced mine with one the same. I would need to check mine to see if i took the square bit off as i did think it located into the base of the steering column end, but it was a while ago that i did it! The rubber bit looks like the boot on the steering rack where it comes out of the rack to go up to the column (see image link) i have removed the damper on mine as have a damper in the Borgeson UJ. the steering rack has a couple of spring clips to hold bits in so could those blue ones be from that? http://www.theopelproject.com/wp-content/uploads/2018/08/IMG_20180829_1948514.jpg The other pic looks like the collapsible part of the inner column? they have to plastic plugs that brake so the column collapses rather than harpoon you! Andy Quote Link to comment Share on other sites More sharing options...
moodoo Posted January 14, 2021 Author Share Posted January 14, 2021 Thanks Andy. OK, I figured out what the blue things are, they are just the retainers to keep the rubber boot on! D'oh! That boot actually goes over the end of the column, in the engine bay, to keep dirt out of the lower bearing. I had an old scrap column, which I disassembled. The old felt bearing has two round 'things' on the outer diameter, which retain in 2 round holes in the fixed bit of the column. The replacement new bearing has a rectangular bit, which does actually align with a rectangular notch in the column. Strange that Opel seemed to make the column suitable to use either type of bearing? My only remaining question is what retains that new bearing in the column? I could push it in, it's probably a tightish fit I'm guessing, but there's nothing to actually retain it. Should I be using some sort of adhesive, to bond it to the inside of the bottom of the column? Or is the press fit good enough? Quote Link to comment Share on other sites More sharing options...
611 Posted January 14, 2021 Share Posted January 14, 2021 Hey Fin My memory was not too far off! Now i see your other pic was of the old bush not the but further up where is collapsible. I think the column is the same (or very similar) on A and B and i think it was more an upgrade on the B for the bearing one as the old felt ones dont last that long. Never used anything to retain mine, the push fit seems fine, been on there for years with no issues. Never realised they had a boot on the!! is it big enough to fit right over the end of the column? Andy Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted January 18, 2021 Share Posted January 18, 2021 if its the same idea as the b there is a spring between the lower bearing and the u/j .this will hold the bearing in and keeps the bearing races inside it firm. the lower bearing has lots of side movement unless held together 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted January 18, 2021 Share Posted January 18, 2021 also looking at mine. the slot is deeper and the bearing goes up to the shoulder .you may have to mod yours if its not as it may hold it at an angle with the spring in Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 18, 2021 Share Posted January 18, 2021 I guess this the same for Ascona A ? Quote Link to comment Share on other sites More sharing options...
moodoo Posted January 30, 2021 Author Share Posted January 30, 2021 On 18/01/2021 at 07:38, cam.in.head said: if its the same idea as the b there is a spring between the lower bearing and the u/j .this will hold the bearing in and keeps the bearing races inside it firm. the lower bearing has lots of side movement unless held together There’s no spring involved on the a series, at least on mine. I guess I could add a spring, but would need to put some sort of seat on the top of the UJ to locate the spring. Although based on what Andy said, mightn’t be needed? I guess the push fit, plus maybe some adhesive would probably retain it. The spring behind the steering wheel means the force on the shaft is upwards in any case, so nothing to push the bearing down anyway? Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted January 31, 2021 Share Posted January 31, 2021 if you use that particular type of lower bearing you will need a spring. it just sits on the uj itself,nothing fancy but the bearing has sideways movement in it unless held up. also the slot in the column needs deepening or the bearing modifying if you fit it otherwise it will sit at an angle . unless others know otherwise this style was not fitted originally and just had a nylon bush with the location stub hence no need for a spring . Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted February 1, 2021 Share Posted February 1, 2021 I'm going to guess that the oem bearing/bush could then be just 3Dprinted ? Quote Link to comment Share on other sites More sharing options...
moodoo Posted February 1, 2021 Author Share Posted February 1, 2021 Yeh, in theory it could be printed, once you picked the right material, something self lubricating. Ideal would be to print the outer housing with the locating stubs, and then into that fit a proper dry sleeve bearing, so you’d have bearing material in the right place, not relying on the print. 1 Quote Link to comment Share on other sites More sharing options...
Bruce Hockley Posted October 10, 2021 Share Posted October 10, 2021 Has anyone got a link or part number for the lower bush please? My A has just a rubber shoved in the bottom that sticks and makes the steering hard even when jacked up. Can't seem to find one online. Quote Link to comment Share on other sites More sharing options...
611 Posted October 10, 2021 Share Posted October 10, 2021 3 hours ago, Bruce Hockley said: Has anyone got a link or part number for the lower bush please? My A has just a rubber shoved in the bottom that sticks and makes the steering hard even when jacked up. Can't seem to find one online. If your going to fit the later one like Moodoo has in the pic further up the part number is. (which i would recommend) Steering Column Bottom Bearing – 90023940 1 Quote Link to comment Share on other sites More sharing options...
Bruce Hockley Posted October 13, 2021 Share Posted October 13, 2021 (edited) Just to let everyone know, I rang Vauxhall parts today and that number is out of date. He couldn't help with cross reference without vehicle vin or reg but said he would try and get an updated number from their suppliers. Edited October 13, 2021 by Bruce Hockley 1 Quote Link to comment Share on other sites More sharing options...
moodoo Posted October 13, 2021 Author Share Posted October 13, 2021 I got a mate of mine in Poland to get one for me, some sort of Daewoo or other used the same. 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted October 14, 2021 Share Posted October 14, 2021 23 hours ago, moodoo said: I got a mate of mine in Poland to get one for me, some sort of Daewoo or other used the same. Can you ask for the part number? Might have been that MK2 Astra looking Daewoo 🤔 Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted October 14, 2021 Share Posted October 14, 2021 http://dr-manta-shop.de/epages/0859c4be-b99b-4b88-8216-6a78b07dc4b5.mobile/de_DE/?ObjectPath=/Shops/0859c4be-b99b-4b88-8216-6a78b07dc4b5/Products/03320006 Quote Link to comment Share on other sites More sharing options...
611 Posted October 14, 2021 Share Posted October 14, 2021 5 minutes ago, Mickfrad said: http://dr-manta-shop.de/epages/0859c4be-b99b-4b88-8216-6a78b07dc4b5.mobile/de_DE/?ObjectPath=/Shops/0859c4be-b99b-4b88-8216-6a78b07dc4b5/Products/03320006 WOW, 75 euros, i should have bought a whole bunch of them at the time!! Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted October 14, 2021 Share Posted October 14, 2021 1 minute ago, 611 said: WOW, 75 euros, i should have bought a whole bunch of them at the time!! Plus postage 1 Quote Link to comment Share on other sites More sharing options...
moodoo Posted October 15, 2021 Author Share Posted October 15, 2021 21 hours ago, Jessopia74 said: Can you ask for the part number? Might have been that MK2 Astra looking Daewoo 🤔 It was the same number as the GM one I think...and it cost a whole €3! 1 1 Quote Link to comment Share on other sites More sharing options...
