Sutty2006 Posted May 1, 2021 Share Posted May 1, 2021 Does anyone have this carb on their manta? I need some pictures of it. I can see where the throttle cable goes, but I have another lever with a ball on the pivot and a bracket for a Boden cable, but the way it levers doesn’t make sense. So I could do with seeing a working one... the red arrow points to the ball in particular. Is that a manual choke setup? If so, how is the cable routed? Quote Link to comment Share on other sites More sharing options...
rutts Posted May 1, 2021 Share Posted May 1, 2021 Ballsocket pushes on with a leaver sticking out into throttle bracket. Think I have one in unit. Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 2, 2021 Author Share Posted May 2, 2021 10 hours ago, rutts said: Ballsocket pushes on with a leaver sticking out into throttle bracket. Think I have one in unit. If you could have a look that would be great. The ball nut doesn’t move, it just rotates and the bracket coming off to the left goes up and down. Doesn’t make much sense . Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 2, 2021 Share Posted May 2, 2021 2 hours ago, Sutty2006 said: If you could have a look that would be great. The ball nut doesn’t move, it just rotates and the bracket coming off to the left goes up and down. Doesn’t make much sense . From that picture and what you are saying I think the bracket on the butteryfly spindle out of carb is sat under its movement mechanism, when it should be on top. Look at blue operation arrow in picture. From memory, the rest of the mechanism is as close to drawing Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 2, 2021 Author Share Posted May 2, 2021 Thanks I’ll have another look when I get home. What’s the red line? It that a bar that goes a cross to lever the lever? Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 2, 2021 Share Posted May 2, 2021 4 hours ago, Sutty2006 said: Thanks I’ll have another look when I get home. What’s the red line? It that a bar that goes a cross to lever the lever? Think so, although it's positioning would be different . I seem to remember some spring or mechanism there Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 2, 2021 Author Share Posted May 2, 2021 I think that bracket only goes on one way, as there is a slit in it where it mounts to the rod coming out of the carb. So it would sit 180 degrees too... Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 2, 2021 Author Share Posted May 2, 2021 Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted May 2, 2021 Share Posted May 2, 2021 I can take some pics of the setup i have on the ascona for you tomorrow - it should show you everything you need to know. Do you not have the throttle linkage which bolts to the inlet manifold ? Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 2, 2021 Author Share Posted May 2, 2021 28 minutes ago, MrCarlos said: I can take some pics of the setup i have on the ascona for you tomorrow - it should show you everything you need to know. Do you not have the throttle linkage which bolts to the inlet manifold ? It appears not, or the clip that holds the throttle cable in place. What you see in the pictures is all I have. I picked this engine up like it is, and the car had no engine in to begin with. So it’s all new stuff to me on these CIH engines. I’m going up to my unit tomorrow to check what throttle cable I have! Any pictures you have Carl would be great! Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 2, 2021 Share Posted May 2, 2021 Ah! The sprung mechanism was not on that end, it was the other and as it was in an Auto I think it may gave been for the kick down link now thinking more on it. Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted May 2, 2021 Share Posted May 2, 2021 18 minutes ago, Sutty2006 said: It appears not, or the clip that holds the throttle cable in place. What you see in the pictures is all I have. I picked this engine up like it is, and the car had no engine in to begin with. So it’s all new stuff to me on these CIH engines. I’m going up to my unit tomorrow to check what throttle cable I have! Any pictures you have Carl would be great! Hehe its money for old rope with me lol Ill get pics tomorrow and can supply a suitable linkage and cable from stock if needed 🙂 1 1 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 2, 2021 Author Share Posted May 2, 2021 Just now, MrCarlos said: Hehe its money for old rope with me lol Ill get pics tomorrow and can supply a suitable linkage and cable from stock if needed 🙂 Great. Meet you here tomorrow to discuss missing/present parts? 😂 Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted May 2, 2021 Share Posted May 2, 2021 10 minutes ago, Sutty2006 said: Great. Meet you here tomorrow to discuss missing/present parts? 😂 Certainly 🙂 Ive to go to the unit in the am to sell a van so ill get pics while im there 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted May 3, 2021 Share Posted May 3, 2021 Must have a look can supply a backup photo if needed. Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted May 3, 2021 Share Posted May 3, 2021 Heres the setup on my ascona steve 🙂 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 3, 2021 Author Share Posted May 3, 2021 See, that looks different to what I thought it would. Lots going on there. Evo can you get me a pick of yours to compare? Carl that ball headed nut you sent me looks different to the one on yours, you’ve got a 13mm nut instead 🤔 Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted May 3, 2021 Share Posted May 3, 2021 11 minutes ago, Sutty2006 said: See, that looks different to what I thought it would. Lots going on there. Evo can you get me a pick of yours to compare? Carl that ball headed nut you sent me looks different to the one on yours, you’ve got a 13mm nut instead 🤔 Yes i spotted that lol, there are all sorts of different variations on the linkages and after market conversion sets. Thats the set up for a 2.0 varijet conversion , but the 1.9 linkage for the zenith carb is different again with the linkage working the other way round and a big long throttle cable looping all round the engine I can sell you a linkage with matching short throttle cable which will work with the ball thingy for £30 plus postage and packing which will be a nice simple solution! 1 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 3, 2021 Author Share Posted May 3, 2021 Well I’m definitely missing a throttle cable. Can you get me a picture of it? So that I can compare it to the setup on my manifold? Sorry to be a pain in the buttocks. ive got a feeling I’m going to need the exact Weber linkage assembly, as I recon this was converted early on in its life. Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted May 3, 2021 Share Posted May 3, 2021 27 minutes ago, Sutty2006 said: Well I’m definitely missing a throttle cable. Can you get me a picture of it? So that I can compare it to the setup on my manifold? Sorry to be a pain in the buttocks. ive got a feeling I’m going to need the exact Weber linkage assembly, as I recon this was converted early on in its life. Sure , ill get some pics tomorrow for you 🙂 1 Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted May 4, 2021 Share Posted May 4, 2021 Pics here steve - should be ideal for you 🙂 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted May 4, 2021 Share Posted May 4, 2021 Pics, 2.0 with weber 1.6 with solex Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 4, 2021 Author Share Posted May 4, 2021 I’m still trying to picture everything attached to mine..... it’s difficult to see it in action. Something doesn’t quite look right. 🤔😩 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted May 4, 2021 Share Posted May 4, 2021 Think your bracket is on back to front. Cable slit should be at outside. On 01/05/2021 at 20:46, Sutty2006 said: 1 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 5, 2021 Author Share Posted May 5, 2021 You might be on to something there......... Quote Link to comment Share on other sites More sharing options...
