2.0E Cih & Getrag 5 speed box project.
Mike.
I recently got the opportunity to pick up this 2.0E Cih engine and Getrag 5 speed gearbox locally, it’s from an 1986 C reg Manta coupe which was stripped and prepared for rallying. My intention is to strip down and re build so I have a reconditioned engine and box ready to go, plus it gives me a small project just to keep me busy.
The 2.0E cih with P2E head,
Getrag 5 speed gearbox,
starting to strip off all ancillaries and box them up,
ready to clean when I get a minute,
flywheel bolt removed, probably easier on the pallet rather than in the engine bay,
Clutch plate and clutch removed, P bolt marked and flywheel removed so I can mount the engine on the engine stand,
Rocker cover, timing casing/ oil pump and sump all stripped, cleaned and painted,
engine mounted on stand and block de greased, wire brushed and painted with HT engine paint just to keep things cleaner in the garage, now I can work on it with getting oil everywhere,
my next job will be to start cleaning the inlet manifold, exhaust manifold etc so I have clean parts to work with then the full strip down and re build, probably a autumn/winter project.
had a quick go over a small part of the gearbox with a wire brush to get an idea of the final results with the box, looks encouraging, loads more time needed on this along with an oil change,
  • Like 10
I know exactly what you mean, the small orange o ring, like a cutting of hose on top left of timing case. I have cleaned all faces of timing case, head and block but as yet I haven’t purchased a complete gasket set, that’s on my to do list for assembly in the Autumn, along with oil stem seals and head bolt set I need to purchase these parts so in the meantime I’m pushing forward with cleaning and dismantling in preparation. I also have a Kent 214 fast road cam which I intend to fit but don’t know if my existing hydraulic lifters will do or if I need to purchase solid lifters?
Edited by Mike.
