Jonathan Pounsett Posted July 1, 2021 Share Posted July 1, 2021 Has anyone any knowledge of these? What’s the quality like? https://www.ebay.co.uk/itm/124783639501 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted July 1, 2021 Share Posted July 1, 2021 I wonder if they’re all the same key? 🤔 and I mean, between sets…… Quote Link to comment Share on other sites More sharing options...
Snowy Posted July 2, 2021 Share Posted July 2, 2021 11 hours ago, Sutty2006 said: I wonder if they’re all the same key? 🤔 and I mean, between sets…… I have asked them this question as I want to buy two sets and they've told me that each set has a unique key and one will not fit the other. 2 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted July 2, 2021 Share Posted July 2, 2021 51 minutes ago, Snowy said: I have asked them this question as I want to buy two sets and they've told me that each set has a unique key and one will not fit the other. Excellent effort sir 👍 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted July 22, 2021 Author Share Posted July 22, 2021 I’ve got a set of these now. Door and boot locks are really good and look like the originals. The ignition looks a bit cheaper and is a bit “notchy“ but this may improve with use. Same key fits them all but isn’t great quality - 2 keys supplied. No sealing gasket or fixing clips were included in the pack which was a bit disappointing. 3 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted July 26, 2021 Author Share Posted July 26, 2021 BEWARE!!!! The outer casing has been manufactured to a slightly smaller diameter. This gave me three issues to overcome; 1. The rubber gasket is visible around the lock. This is only an aesthetic issue and will not be detrimental to its performance. I think it looks like I used the wrong gasket and it will bug me every time I lock or unlock the car. (No central locking). 2. As the casing diameter is smaller it feels lose in the hole. I think over time it will “sink” showing more of the gasket at the top and possibly even allowing water penetration. 3. The old locking springs/clips need to be reused as none are provided in the kit. Resizing the spring was a tricky operation as by its nature it returns to its normal state. Unfortunately to achieve the right amount of adjustment required exceeding it elastic limit and both door springs are slightly out of shape and don’t lay flushly(?) against the inside of the door. If you don’t like “flushly” substitute “correctly”. My fear is that they will fail at some point in the future and the springs will drop out. I don’t think the lock itself is in danger of dropping out as it will still be attached to the mechanisms connecting rod. Having said that they work ok and are inexpensive compared to sourcing matching lock sets. I’m not going to change the ignition unless/ until it breaks. 🙂 1 1 Quote Link to comment Share on other sites More sharing options...
les87GTE Posted July 26, 2021 Share Posted July 26, 2021 Thanks for all the info and pictures regarding these as I have been looking at them for a while. Knowing what you know now, would you buy them again? And if not, where else can one go? Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted July 27, 2021 Author Share Posted July 27, 2021 13 hours ago, les87GTE said: Thanks for all the info and pictures regarding these as I have been looking at them for a while. Knowing what you know now, would you buy them again? And if not, where else can one go? I would buy them again Steve, but only as a temporary measure until I could find a good original set. Look on eBay Kleinanzeigen search “Opel Manta B turschlosser”. 1 Quote Link to comment Share on other sites More sharing options...
